Aiuto jrk x-sim
Aiuto jrk x-sim
Postby Salvomilitello » Thu 31. Dec 2015, 16:20
Salve a tutti sono nuovo del forum volevo una mano a configurare xsim con le jrk e due motori valeo 404.... Ho provato ma niente nessun movimento.
Anche se nell'appl 3d il sim si muoveva ora ho pulito il programma e resettato da zero....per non perdere tempo mi sn fermato e aspetto un aiuto.....è da un po' che mi ci ammazzo ma niente grazie a tutti in anticipo
Salvomilitello
Re: Aiuto jrk x-sim
Postby sirnoname » Thu 31. Dec 2015, 21:05
Did you follow the training video and JRK video? Did you read the JRK instructions. There are two possible ways. One with USO and low resolution. The other option is the PnP plugin and high resolution (more positions).
Re: Aiuto jrk x-sim
Postby Salvomilitello » Fri 1. Jan 2016, 15:53
I have followed the training and I entered the Jrk high resolutionplugin but do not move the motor only moves in 3d sim i use sinaptrix setup
si ho seguito il training e ho inserito il plugin jrk alta risoluzione ma non si muovono i motori si muove solo nel 3d sim
Salvomilitello
Re: Aiuto jrk x-sim
Postby sirnoname » Fri 1. Jan 2016, 16:22
Profile export or screenshots?
Re: Aiuto jrk x-sim
Postby Salvomilitello » Fri 1. Jan 2016, 16:32
I dont have a profile becouse I tried to make a profile and does not move and I deleted everything you can help me to do a profile? I do not know how to use this xsim
Salvomilitello
Re: Aiuto jrk x-sim
Postby Salvomilitello » Fri 1. Jan 2016, 16:35
Tonight place photos of setup I had doneI.... I would like to create a simple profile with gear shift acceleration and braking curves and perhaps beyond it perfected
Salvomilitello
Re: Aiuto jrk x-sim
Postby Salvomilitello » Fri 1. Jan 2016, 16:58
I hope you can help me is a year that I try and I'm losing hope
Salvomilitello
Re: Aiuto jrk x-sim
Postby Salvomilitello » Fri 1. Jan 2016, 17:53
Do you have a base profile for me?
Salvomilitello
Re: Aiuto jrk x-sim
Postby Salvomilitello » Fri 1. Jan 2016, 17:55
I
Salvomilitello
Re: Aiuto jrk x-sim
Postby sirnoname » Fri 1. Jan 2016, 21:04
So you did not the step by step tutorials?
Return to Italy forum
