configuring X-sim for NoLimits Rollercoaster
Postby Mertensbart20 » Sat 8. Dec 2012, 13:03
Hello everybody,
I am a teacher electrical engineering and this year I am building a 2DOF racingsim with my students that is based on the design of the CKAS Thruxim. Should you be interested you can follow our work here:
viewtopic.php?f=37&t=335
We are also going to use the simulator as a rollercoastersimulator for NoLimits Rollercoaster which can be found here:
http://www.nolimitscoaster.com/
For this I have written a document to help people set up the X-sim software to extract motiondata from NoLimits Rollercoaster. This document "Configuring X-sim for NoLimits Rollercoaster.pdf" along with a X-sim converter file "rollercoaster.rn2" can be found in the "Configuring X-sim for NoLimits Roller Coaster.rar" file that is attached in this message. I also included the word-document "Configuring X-sim for NoLimits Rollercoaster.doc" in the rar-file for people who would like to edit the document.
Hope this helps people converting their racesimulator in a rollercoastersimulator.
Greetings,
Bart
(2.85 MiB) Downloaded 1873 times
Mertensbart20
Re: configuring X-sim for NoLimits Rollercoaster
Postby motiondave » Sat 8. Dec 2012, 14:13
Groovy and thanks for that. I will have a read....
Postby Mertensbart20 » Sat 8. Dec 2012, 16:24
Hello motiondave,
I have included the word-document if you would want to make changes (see the new attachment). Makes editing easier.
Greetings,
Bart
(2.85 MiB) Downloaded 1341 times
Mertensbart20
Postby Riton » Sat 15. Dec 2012, 15:19
Hi
there are a problem with motion driver and roller caoster.
When i press start in converter , the simulator stop, but i have the red start, there are no motion in input setup in converter.
I can see motion number on the graphic driver, but i have not see anything in the converter.
thanks
Riton
Images: 70
Been thanked: 16 times
Postby sirnoname » Sat 15. Dec 2012, 15:34
Did you setup the right side of the motion driver?
There is a list which value of the memory driver will be transfered to which slot in the converter.
By the way, you have to write down each importand detail, for example I do not know if you are using the memory driver or the graphic driver. Both are parts of the motion driver you did wrote :D
Make screenshots etc., else you will have no quick support because we have to pull all infos out of your nose.
Postby Riton » Sat 15. Dec 2012, 16:49
I transferred the list, now I have values ​​in xsim Converter, but I still have the problem in converter:
the tutorial I have not figured out how to transfer the list.
When I press start, it cuts the simulator.
it is not very easy to understand.
Values ​​may not be good.
Riton
Images: 70
Postby Riton » Sat 15. Dec 2012, 17:07
I need to take the tutorial,
http://www.x-sim.de/documents/X-Sim%20E ... 0Guide.pdf
I have to translate, then try to translate it because it is quite difficult.
I do not understand how to use, as I did not understand, I get nothing at all.
once in French I would come to understand.
I used the. rnr highest attachment with the tutorial, this may be why it does not work well, I have to make my own with my profile axis I
I ask for help for translation into French
Riton
Images: 70
Postby tommy6 » Thu 27. Dec 2012, 15:23
Hello, I wanted my simulator test times with Rollercoaster. How can I get for key stage 1 :?:
Thx´s
tommy6
Images: 51
Been thanked: 5 times
Postby Mertensbart20 » Thu 27. Dec 2012, 21:12
Hello Tommy6,
If you read the document "Configuring X-sim for NoLimits Roller Coaster.pdf" in the rar-file you can find that information in "1.Things to know before further reading".
Greetings,
Bart
Mertensbart20
Postby museumsteve » Sat 20. Apr 2013, 00:27
I've just come back to look at No limits again and I cannot get proper motion :(
I tink it's all set right but I get no value changes in slots 21/22/23 which I believe are the ones I use. I can see changing values in other slots but they're listed as objects and roll pitch speed etc which are related to the view and not g forces.
In Motion Driver I have enabled Graphic Driver and Memory Driver
This is the first time I tried since moving to x-sim3 so maybe I missed something obvious.
museumsteve
Return to NoLimits Roller Coaster
