iracing ?? how to
iracing ?? how to
Postby fortress » Fri 30. Mar 2012, 02:24
hi!! i really dont understand how to use that software. I just want to play iracing. I'm so confuse.. how can i make my motion work??
fortress
Re: iracing ?? how to
Postby sirnoname » Fri 30. Mar 2012, 10:17
At the moment you can only get the beta, there is no tested iRacing plugin.
Are you firm with iRacing and can test the next week some implementations then open a bug tracker and it will be solved.
Postby shannonb1 » Fri 27. Apr 2012, 16:35
"At the moment you can only get the beta, there is no tested iRacing plugin.
Are you firm with iRacing and can test the next week some implementations then open a bug tracker and it will be solved."
Does iWrap not work wiht x-sim 3?
shannonb1
Return to iRacing
