Does not work after the update today 8.3.2016  Topic is solved solved with post #18967
Postby metzger » Tue 8. Mar 2016, 23:38
I get no data from the game, tried different things like adding it manualy, switching to 32/64 dx9/dx11 nothing helped :(
metzger
Re: Does not work after the update today 8.3.2016
Postby KristofferHof » Wed 9. Mar 2016, 23:34
I've got the same problem. 32/64 and DX9/11 doesn't change anything. The slider test panel does send data to the converter, so it's not a problem between the extractor and converter.
KristofferHof
Re: Does not work after the update today 8.3.2016  Topic is solved
Postby KristofferHof » Wed 9. Mar 2016, 23:45
I think I've found a solution to our problem metzger!
1. Navigate to your iRacing folder. Usually in C:\Users\"Your username"\Documents\iRacing
2. Open the app.ini file
3. Locate "enableLegacyTelemetry="
4. Mine was set to 0, but when I changed it 1 and saved the file, I've now got my inputs working again.
I hope this can help you. Please mark my post as "answer" if it did, so we can help others too.
KristofferHof
Postby metzger » Fri 11. Mar 2016, 17:41
KristofferHof wrote:I think I've found a solution to our problem metzger!
Fixed :)
Thanks!
metzger
Postby rpower » Sun 13. Mar 2016, 18:19
dear KristofferHof
fntastic
SOLVED
thx
rpower
Return to iRacing
