"Rfactor not working" message after fresh instal
Postby baileysw » Sun 24. Feb 2013, 06:01
Guys,
I have a fresh install of rFactor and X-Sim on a PC running Windows 7, dual core duo processor.
rFactor had been working fine for a few weeks and when I first installed X-Sim, it detected rFactor and then rFactor would no longer work. X-Sim extractor seemed to be working fine in Task Manager.
So I removed X-Sim and rFactor, then reinstalled both. RFactor worked fine again and as soon as I completed the install of X-Sim and started extractor, then tried to restart rFactor, the same error message came up again.
I have searched through the forums but nothing jumps out.
Any ideas from anyone?
baileysw
baileysw
Re: "Rfactor not working" message after fresh instal
Postby baileysw » Sun 24. Feb 2013, 09:02
Hi Bobbuilt,
Thanks for that. Turns out I forgot to reboot after setting UAC. Have resolved that issue.
Now I can only get the extractor window up on a new install. After the first time, opening extractor does nothing.
I need to set the IP address for the converter on another PC and can only think that I have to do a fresh install to get it to work.
I'll keep plugging away.
baileysw
Postby baileysw » Mon 25. Feb 2013, 06:50
Thanks Bobbuilt,
That got me going OK.
It was just a matter of starting things in the right sequence and then pressing the right buttons.
Looks like it's going fine *
Now to start looking at the next step - processor and controller options.
Steve
baileysw
Postby dayf1 » Thu 22. May 2014, 22:09
I have the same problem.
I've instaled rFactor v1.255
I've instaled X-sim
When I start X-sim and clic to play game, when I select the circuit the game close automaticly.
After that rFactor doesn't work anymore even without using X-sim.
Can somebody tell what have I to do?
I have copied the plugin and it doesn't work.
dayf1
Postby sirnoname » Thu 22. May 2014, 22:22
Why you copy yourself if X-Sim do copy the plugin correctly for you?
Seems you did something wrong with your copy.
Postby dayf1 » Sat 24. May 2014, 00:49
I know that Xsim do it. The first time I run the programme I didn't copy the plugin but then I copied to try something different.
dayf1
Postby dayf1 » Sat 24. May 2014, 12:05
I have tried to download rfactor demo from the official page and I have the same problem.
I open xsim xtractor.
I clic on play game
rFactor starts.
When I have to load the circuit the game close automaticly.
What can I do??
Help please!!
dayf1
Postby sirnoname » Sat 24. May 2014, 12:11
remove other plugins
Postby dayf1 » Sat 24. May 2014, 13:38
From rfactor plugins folder?
dayf1
Postby dayf1 » Sat 24. May 2014, 15:04
dayf1
Return to rFactor & rFactor 2
