rfactor2 Occulus CV1 Steam Vr
Postby JensGo » Thu 31. Oct 2019, 20:27
Hello,
i am waiting for hardware parts so i used the time to get the software running. after several hours rfactor2, assetto corsa and competizione these programs send data to the extractor. i flashed an arduino nano with latest xpid.ino
then i tried to use the games with rift.
asetto corsa is runnig fine <- native occulus support
rfactor 2 has no native support for occulus i have to use the openvr interface.
a) i used original openvr_api.dll -> steamvr is needed i get an error no vr headset found
b) usually i use a special version of opencomposite openvr api. i get an error too .
extractor and XSimRF2Plugin_64.dll dont like openvr / steamvr.
is there a walkaround ?
Jens
JensGo
Re: rfactor2 Occulus CV1 Steam Vr
Postby sirnoname » Fri 1. Nov 2019, 09:56
RF2 must like any plugin in its folder.
What is happening exactly.
Make a share and provide your plugin folder for reproduction.
Postby JensGo » Fri 1. Nov 2019, 16:44
i start extractor, converter is loaded automatically. i choose rfactor2 in extractor programm and press start button
rf2 is starting ---- rf2 launcher is ready,
when i start single or multiplayer mode i get an error and am again at the launcher
4771477247734774
i removed rFactor2SharedMemoryMapPlugin64.dll and DRSShiftBeeps.dll to check if there are problems with xsim plugin . i did not help.
when i deactivate the vr support and use single screen. xsim is working.
JensGo
Postby sirnoname » Fri 1. Nov 2019, 16:56
For a test, use this option without start RF2 from X-Sim:
https://www.x-sim.de/manual/autoscan.html
It is in the motion driver dialog.
Postby JensGo » Sat 2. Nov 2019, 17:57
today i don´t get any errors . i don´t understand it. i did not change anything
i tried several ways to start rf2 and everytime its working,
JensGo
Postby sirnoname » Sat 2. Nov 2019, 18:03
Maybe a problem or hangup with the memory driver direct X injection. Do not use this or the force feedback driver.
A restart of the PC is never wrong to start from fresh.
Return to rFactor & rFactor 2
