DX11 version doesn´t work  Topic is solved solved with post #21289
Postby dualin » Tue 2. May 2017, 14:19
Hi, I´ve updated the rfactor game to the DX11 version, and the game doesn´t start. If I delete the x-sim plugin from the plugins folder (bin64/plugins) then the game works well, but with the plugin in that folder the game doesn´t start. I´ve read that the plugins for DX9 don´t work, I don´t know if that it the reason.
Can you help me??
Sorry for my poor english
Best regards and thanks in advance.
Dualin
dualin
Images: 7
Re: DX11 version doesn´t work
Postby dualin » Thu 4. May 2017, 16:00
Nobody??
Sirnoname, can you help me?? The plugin has anything about dx9. In the new versión only works the plugins compatible with DX11
Best regards
Dualin
Enviado desde mi UMIDIGI Z mediante Tapatalk
dualin
Images: 7
Postby spyderwash » Thu 4. May 2017, 23:42
I have no problem maybe depends on executable do you start from bin64?
C: \ Program Files (x86) \ Steam \ steamapps \ common \ rFactor 2 \ Launcher
spyderwash
Postby dualin » Fri 5. May 2017, 00:28
spyderwash wrote:I have no problem maybe depends on executable do you start from bin64?
I start from steam, i'll try from the executable directly.
Best regards
Dualin
dualin
Images: 7
Postby spyderwash » Fri 5. May 2017, 01:39
Use launger executables and you'll see it work
And put steam parameters
spyderwash
Re: DX11 version doesn´t work  Topic is solved
Postby dualin » Mon 8. May 2017, 11:16
Now It solved. The problem was that i was tried the Rfactor2 without execute the xsim software. Then the Rfactor2 doesn't work if i have the plugin in It folder. But if i execute Rfactor2 from xsim software or with the xsim un the background Rfactor2 works well.
Thanks.
Dualin
dualin
Images: 7
Return to rFactor & rFactor 2
