RFactor 2 Plugin
Re: RFactor 2 Plugin
Postby motiondave » Sun 24. Jun 2012, 01:20
you are welcome
Postby kevin123 » Mon 25. Jun 2012, 19:06
kevin123
Images: 132
Has thanked: 15 times
Been thanked: 11 times
Postby didg » Wed 4. Jul 2012, 21:11
Big Thanks sirnoname for the plugin rf2
didg
Images: 3
Postby Nnexxus » Sat 5. Jan 2013, 19:19
Thanks for this plugin ! I'm using it to feed my arduino dashboard and it's working great.
Just a couple of notes : the fuel capacity seems to be shifted by one (on the HUD it says 46 but in X-Sim it's 47), and the temperatures of all 4 wheels are not in the right slot. Those are just minor inconveniences.
Do you think it would be possible to add the player's position in the race ? I'd like to display this on my dashboard, but the value in X-Sim remains at 0...
Nnexxus
Postby RafBR » Sat 23. Mar 2013, 20:16
I am almost sure the latest rf2 build is not working with x-sim motion plugin. Have anyone noticed it too?
RafBR
Images: 24
Postby sirnoname » Sat 23. Mar 2013, 21:47
All the time I try to start a race in rf2 it crashes.
I did: install the rfactor installer, downloaded the racing school, create a packages folder in /core and copy the rfmod there. Then I installed with the mod manager the school and closed the manager. Then I go into rf2 and select a car, a track and a series. If I press start it loads but crashes in 50 to 80% of the load progress bar.
I tried this on two different computers with same result and I tried some posts which says to enable HDR rendereing without success.
Postby RafBR » Sat 23. Mar 2013, 22:10
Hi Sir,
Here it is working fine... and motion aswell :oops: my problem with motion was just my fault.
RafBR
Images: 24
Postby sirnoname » Sat 23. Mar 2013, 22:59
I tried to insert a autoscan and setup script but I do not get it working.
Can you tell me which track package you are using and which car you have downloaded that it is working?
Postby RafBR » Sun 24. Mar 2013, 00:24
Hi Sr,
I had big trouble when I first bought the game a year ago. Game Always crashing... couldnt start even once.
The only thing that solved my issue was installing it in c:\rfactor2
Yes, the root c:
In my case (i dont know why) the game had some kind of user account control issue... I remember I had even to lower the UAC slider (Win7).
My regards
RafBR
Images: 24
Postby sirnoname » Sun 24. Mar 2013, 02:53
I did as you said and - oh wonder - now I got a packages directory from the installer which was not there if I install it to "program files (x86)". I added it manually.
And - oh wonder - now it starts.
Tomorow I will check this on my develpment PC.
One question is open: where to copy the rf2 x-sim plugin?
Return to rFactor & rFactor 2
