dirt3 helps  Topic is solved solved with post #230
Re: dirt3 helps
Postby mrconsoler » Mon 30. Dec 2013, 22:13
I have Dirt 3 Steam Version, Windows 8 x64, and the game freezes when I cross the finish line. I have read this topic, but I didn't find any fix... Can you explain excatly what is causing this problem?
mrconsoler
Re: dirt3 helps
Postby Riton » Wed 26. Nov 2014, 09:06
Reverse checkbox must be checked
26 for effect?
this effect is reversed in comparison with other?
Riton
Images: 70
Been thanked: 16 times
Re: dirt3 helps
Postby Rusty » Sun 28. Dec 2014, 21:16
mrconsoler wrote:I have Dirt 3 Steam Version, Windows 8 x64, and the game freezes when I cross the finish line. I have read this topic, but I didn't find any fix... Can you explain excatly what is causing this problem?
I feel the same , for it can be?
Rusty
Images: 8
Re: dirt3 helps
Postby mreiner » Mon 29. Dec 2014, 10:57
This problem came with patch 1.2
You have to manually install patch 1.1 over the game and turn auto update off for the game in steam.
mreiner
Images: 22
Been thanked: 15 times
Re: dirt3 helps
Postby Rusty » Mon 29. Dec 2014, 21:47
mreiner wrote:This problem came with patch 1.2
Thank you very much for your help. I just downloaded the 1.1 path as intale in the game directory and hangs at the finish .
Rusty
Images: 8
Re: dirt3 helps
Postby arne » Mon 26. Jan 2015, 20:33
Hey,
I can't get any values of the game in X-sim. It worked just one time. Does anyone have an idee?
I use the third2 plugin and I change the code.
But when I play, x-sim use always port 20778 and not 20777.
How do I change that and how can I change the path?
2DOF: X-sim - Arduino - Motomonster
http://www.x-sim.de/forum/viewtopic.php?t=1640
arne
Images: 31
Re: dirt3 helps
Postby sirnoname » Mon 26. Jan 2015, 21:41
Taskbar- open minimized Dirt plugin, remove and undo the port settings. Seems you have played around with the pass through option.
Re: dirt3 helps
Postby varusimulator » Fri 11. Dec 2015, 14:55
Hello,
I am having problems when I try to play LAN multiplayer game between 2 simulators. The game starts and after a short period of time the game freazes. I receive this error: X-Sim Convertor has stopped working. I would apreciate a little help with matter. Do you have any contact number where I could reach you. Thanks, Virgil
varusimulator
Re: dirt3 helps
Postby varusimulator » Fri 11. Dec 2015, 15:06
I have two 6 DOF simulators and they have Dirt 3 installed. The plugin is configured for Dirt 3 the game runs great in single player but in LAN multiplayer it freazes. If I install another game Assetto corsa can I play it using the DIRT 3 plugin or are there different settings for this game? I would apreciate a little help on this. Best Regards, Virgil
PS: Merry Christmass to you all
varusimulator
Re: dirt3 helps
Postby sirnoname » Fri 11. Dec 2015, 17:46
Codemaster games are buggy and freeze with enabled simulator output.
Search this forum for F1 2015 and try this plugin with extradata = 2 in the HW config xml file.
Do it change something?
Assetto has other plugin if you search the forum.
Return to Dirt
