Cheap SCN5 starter kitts (35€/pc)
Postby sirnoname » Wed 12. Jun 2013, 15:57
Hello,
we have build some adapter sets for SCN5 actuators and have now some left overs.
If you plan to buy a complete SCN5 starter Kitt you can get the SCN5 directly from the mirai factory outlet with best shipment prices and get from here one of that wired with converter.
https://miraiintertech.com/e-store/products/SCN5.html
Ask the shop for used SCN5 and running discounts!
Additional you must search for a 24V power supply in eBay (4 Amperes). For one SCN5 you need one of the above adapter set. You can choose any of the SCN5 you like, all are supported. SCN6 do need a small modification of the power cable as described in our SCN forum gallery. The RS485 cable will work on SCN5 and SCN6.
The adapter set includes:
-Power cable with ILK set to disabled, an ILK switch (power shutdown) can be connected from GND to ILK.
-RS485 cable with high speed RS485 to USB converter (all connected for plug n play, best converter that is possible for this solution)
Because mirai is the cheapest solution and the above adapter set do only cost 35€ (15€ adapter, 15€ original connectors and 5€ cables) this is a quick entry for people with less solder knowlege.
Compare the prices.
For example the SCN5 100mm ~425$, two of them for 850$.
+ ~44$ for a cable set, two of them 88$ (~6$ shipment)
+ power suply from ebay (~30$, no shipment)
_______________________________
968$ (without shipment)
You can contact me to get one of the left over cables with PM.
Best regards,
SirNoName
