Project Cars on oculus with X-sim - problem  Topic is solved solved with post #19490
Postby alatok » Tue 31. May 2016, 14:37
Hello,
After new patch i cant start project cars on oculus from x-sim, can anyone help me with this problem.
When i want start Project Cars on oculus i must start it by picking that option in steam, but i dont know how should i do it via X-sim.
alatok
Re: Project Cars on oculus with X-sim - problem
Postby sirnoname » Tue 31. May 2016, 17:13
Left side, game properties, parameters.
Normally you make a shortcut in steam to desktop and enter the shortcut text to the parameter.
http://www.x-sim.de/documents/Howto-gam ... cripts.txt
You can also use the autodetection and run the game with steam, X-Sim will detect the running game without starting it.
http://www.x-sim.de/manual/autoscan.html
Taskname is the window name, use latest patch for 64 bit games.
Postby sacro » Sun 19. Jun 2016, 11:46
the same here i try this ...
steam://launch/234630/othervr
sacro
Postby Speedracer » Sun 26. Jun 2016, 03:22
i see that if i clic that it open Pcar in my oculus but where do i white this in the extractor?
thank you
Speedracer
Postby Tummie » Sun 10. Jul 2016, 20:20
Did anyone fix this? Please say yes.... : (
Autoscan doesn't change a thing for me, neither does the mentioned game parameter. ...
Tummie
Postby sirnoname » Mon 11. Jul 2016, 06:17
You must use this in the plugin driver:
And look the presentation viewer video!
Postby Tummie » Mon 11. Jul 2016, 09:21
Ok thanks for the reply! I tried again and now it works so:
Right click tray icon of x-sim extractor -> enable Autoscan.
Right click tray icon-> autoscan settings -> make sure pcars is selected.
Start t h e game in steam - oculus version in other vr mode
Start the pcars profile in the extractor
Start the converter
Now it should work!
Tummie
Postby sirnoname » Mon 11. Jul 2016, 23:17
Its only one of three possible solutions. You can also try the launcher parameter.
Return to Project CARS
