Problem with project cars plugin  Topic is solved solved with post #17657
Postby fabke » Sat 4. Jul 2015, 11:00
Hi everybody,
got a problem with the pcars plugin.
i am not able to get teletry datas from pcars game to the input sektion of the converter. Eg. effekt for gear 23 is selected in the profile but there is shown no effekt in the input sektion of the converter when the game is running. In game shared memory is activated.
Tryed with other game r-factor everything works fine with the input values.
What do i wrong with pcars?
Think you for any hints and solutions.
Fabke
fabke
Re: Problem with project cars plugin
Postby fabke » Sat 4. Jul 2015, 12:53
solved my self, version 5 of plugin works fine
fabke
Postby Behle » Wed 5. Aug 2015, 13:09
Where can i get the Plugin v5?
Behle
Postby abiesiada » Fri 18. Sep 2015, 12:29
Where i find plugin 5?
Project cars doesn't works.
abiesiada
Postby vicpopo » Fri 18. Sep 2015, 12:47
Re: Problem with project cars plugin  Topic is solved
Postby cybertiti » Mon 5. Oct 2015, 00:04
I have the same problem, no data (i need at least lateral and longitudinal force) received by the converter.
I'm using x-sim 3.0.2.9 , Project cars 4.1.0.0.
Use shared memory is checked in pCARS.
My configuration is running perfectly with Race07 demo.
I already cleaned registry with the xsim tool.
I don't know where to find any logs to go further with this issue.
Best regards,
Cybertiti
Cybertiti
cybertiti
Postby sirnoname » Mon 5. Oct 2015, 07:55
And you dl plugin as above said?
Postby cybertiti » Mon 5. Oct 2015, 20:54
Yes I updated to plugin V5, but i think the right plugin version was already installed by default with x-sim 3.0.2.9.
Any other idea why this is not working ?
I forget to say that i'm using pCARS on 64 bits version.
Cybertiti
cybertiti
Postby sirnoname » Mon 5. Oct 2015, 20:59
No, we always have current plugins here in this thread.
Please double check your plugin and shared memory option in the game.
Postby cybertiti » Mon 5. Oct 2015, 21:09
Already done, plugin was replaced by V5 and shared memory is on.
Cybertiti
cybertiti
Return to Project CARS
