Can someone ask them for a euler transformation code to get car oriented accelerations or velocities (same code).
Description:
Storage structure for storing and * shared memory
Copyright (c) MWL. All rights reserved.
#ifndef _SHARED_MEMORY_HPP_
#define _SHARED_MEMORY_HPP_
// NOTES:
// -The shared memory variables will be updated once per graphics frame.
// -Each variable comes with a UNIT, RANGE, and UNSET description where applicable.
// UNITS - Is the numeric form which a variable is stored in (e.g. KPH, Celsius)
// RANGE - Is the min-max ranges for a variable
// UNSET - Is the initialised/default/invalid value, depending on the variables usage
// -Constant/unchanging values are included in the data, such as 'maxRPM', 'fuelCapacity' - this is done to allow percentage calculations.
// -Also included are 7 unique enumerated types, to be used against the mentioned flag/state variables
// *** Types ***
// Header version number to test against
enum
SHARED_MEMORY_VERSION = 2
// Maximum allowed length of string
enum
STRING_LENGTH_MAX = 256
// Tyres
enum
TYRE_FRONT_LEFT = 0,
TYRE_FRONT_RIGHT,
TYRE_REAR_LEFT,
TYRE_REAR_RIGHT,
TYRE_MAX
// Vector
enum
VEC_X = 0,
VEC_Y,
VEC_Z,
VEC_MAX
// (Type#1) GameState (to be used with 'mGameState')
enum
GAME_EXITED = 0,
GAME_FRONT_END,
GAME_INGAME_PLAYING,
GAME_INGAME_PAUSED,
GAME_MAX
// (Type#2) Session state (to be used with 'mSessionState')
enum
SESSION_INVALID = 0,
SESSION_PRACTICE,
SESSION_TEST,
SESSION_QUALIFY,
SESSION_RACE,
SESSION_TIME_ATTACK,
SESSION_MAX
// (Type#3) Terrain Materials (to be used with 'mTerrain')
enum
TERRAIN_ROAD = 0,
TERRAIN_LOW_GRIP_ROAD,
TERRAIN_BUMPY_ROAD1,
TERRAIN_BUMPY_ROAD2,
TERRAIN_BUMPY_ROAD3,
TERRAIN_MARBLES,
TERRAIN_GRASSY_BERMS,
TERRAIN_GRASS,
TERRAIN_GRAVEL,
TERRAIN_BUMPY_GRAVEL,
TERRAIN_RUMBLE_STRIPS,
TERRAIN_DRAINS,
TERRAIN_TYREWALLS,
TERRAIN_CEMENTWALLS,
TERRAIN_GUARDRAILS,
TERRAIN_SAND,
TERRAIN_BUMPY_SAND,
TERRAIN_DIRT,
TERRAIN_BUMPY_DIRT,
TERRAIN_DIRT_ROAD,
TERRAIN_BUMPY_DIRT_ROAD,
TERRAIN_PAVEMENT,
TERRAIN_DIRT_BANK,
TERRAIN_WOOD,
TERRAIN_DRY_VERGE,
TERRAIN_EXIT_RUMBLE_STRIPS,
TERRAIN_GRASSCRETE,
TERRAIN_LONG_GRASS,
TERRAIN_SLOPE_GRASS,
TERRAIN_COBBLES,
TERRAIN_SAND_ROAD,
TERRAIN_BAKED_CLAY,
TERRAIN_ASTROTURF,
TERRAIN_SNOWHALF,
TERRAIN_SNOWFULL,
TERRAIN_MAX
// (Type#4) Crash Damage State (to be used with 'mCrashState')
enum
CRASH_DAMAGE_NONE = 0,
CRASH_DAMAGE_OFFTRACK,
CRASH_DAMAGE_LARGE_PROP,
CRASH_DAMAGE_SPINNING,
CRASH_DAMAGE_ROLLING,
CRASH_MAX
// (Type#5) Current Sector (to be used with 'mCurrentSector')
enum
SECTOR_INVALID = 0,
SECTOR_START,
SECTOR_SECTOR1,
SECTOR_SECTOR2,
SECTOR_FINISH,
SECTOR_STOP,
SECTOR_MAX
// (Type#6) Car Flags (to be used with 'mCarFlags')
enum
CAR_HEADLIGHT = (1<<0),
CAR_ENGINE_ACTIVE = (1<<1),
CAR_ENGINE_WARNING = (1<<2),
CAR_SPEED_LIMITER = (1<<3),
CAR_ABS = (1<<4),
CAR_HANDBRAKE = (1<<5),
// (Type#7) Tyre Flags (to be used with 'mTyreFlags')
enum
TYRE_ATTACHED = (1<<0),
TYRE_INFLATED = (1<<1),
TYRE_IS_ON_GROUND = (1<<2),
// *** Shared Memory ***
typedef struct
// Version Number
unsigned int mVersion; // [ RANGE = 0->... ]
// Session type
unsigned int mGameState; // [ enum (Type#1) Game state ]
unsigned int mSessionState; // [ enum (Type#2) Session state ]
// Unfiltered Input
float mUnfilteredThrottle; // [ RANGE = 0.0f->1.0f ]
float mUnfilteredBrake; // [ RANGE = 0.0f->1.0f ]
float mUnfilteredSteering; // [ RANGE = -1.0f->1.0f ]
float mUnfilteredClutch; // [ RANGE = 0.0f->1.0f ]
// One Time Session
char mPlayerName[STRING_LENGTH_MAX]; // [ string ]
char mCarName[STRING_LENGTH_MAX]; // [ string ]
char mCarClassName[STRING_LENGTH_MAX]; // [ string ]
char mTrackName[STRING_LENGTH_MAX]; // [ string ]
// Timing & Scoring
float mBestLapTime; // [ UNITS = seconds ] [ RANGE = 0.0f->... ] [ UNSET = -1.0f ]
float mLastLapTime; // [ UNITS = seconds ] [ RANGE = 0.0f->... ] [ UNSET = 0.0f ]
float mCurrentTime; // [ UNITS = seconds ] [ RANGE = 0.0f->... ] [ UNSET = 0.0f ]
float mBestSector1Time; // [ UNITS = seconds ] [ RANGE = 0.0f->... ] [ UNSET = -1.0f ]
float mCurrentSector1Time; // [ UNITS = seconds ] [ RANGE = 0.0f->... ] [ UNSET = -1.0f ]
float mBestSector2Time; // [ UNITS = seconds ] [ RANGE = 0.0f->... ] [ UNSET = -1.0f ]
float mCurrentSector2Time; // [ UNITS = seconds ] [ RANGE = 0.0f->... ] [ UNSET = -1.0f ]
float mSplitTime; // [ UNITS = seconds ] [ RANGE = 0.0f->... ] [ UNSET = 0.0f ]
float mEventTimeRemaining; // [ UNITS = milli-seconds ] [ RANGE = 0.0f->... ] [ UNSET = -1.0f ]
// Race Info
unsigned int mLapsInEvent; // [ RANGE = 0->... ] [ UNSET = 0 ]
unsigned int mLapsCompleted; // [ RANGE = 0->... ] [ UNSET = 0 ]
unsigned int mCurrentLap; // [ RANGE = 0->... ] [ UNSET = 0 ]
unsigned int mCurrentPosition; // [ RANGE = 1->... ] [ UNSET = 0 ]
unsigned int mNumberOfCars; // [ RANGE = 1->... ] [ UNSET = 0 ]
unsigned int mCurrentSector; // [ enum (Type#5) Current Sector ]
// Car State
unsigned int mCarFlags; // [ enum (Type#6) Car Flags ]
float mOilTempCelsius; // [ UNITS = Celsius ] [ UNSET = 0.0f ]
float mOilPressureKPa; // [ UNITS = Kilopascal ] [ RANGE = 0.0f->... ] [ UNSET = 0.0f ]
float mWaterTempCelsius; // [ UNITS = Celsius ] [ UNSET = 0.0f ]
float mWaterPressureKPa; // [ UNITS = Kilopascal ] [ RANGE = 0.0f->... ] [ UNSET = 0.0f ]
float mFuelPressureKPa; // [ UNITS = Kilopascal ] [ RANGE = 0.0f->... ] [ UNSET = 0.0f ]
float mFuelLevel; // [ RANGE = 0.0f->1.0f ]
float mFuelCapacity; // [ UNITS = Liters ] [ RANGE = 0.0f->1.0f ] [ UNSET = 0.0f ]
float mSpeed; // [ UNITS = Metres per-second ] [ RANGE = 0.0f->... ]
float mRpm; // [ UNITS = Revolutions per minute ] [ RANGE = 0.0f->... ] [ UNSET = 0.0f ]
float mMaxRPM; // [ UNITS = Revolutions per minute ] [ RANGE = 0.0f->... ] [ UNSET = 0.0f ]
float mBrake; // [ RANGE = 0.0f->1.0f ]
float mThrottle; // [ RANGE = 0.0f->1.0f ]
float mClutch; // [ RANGE = 0.0f->1.0f ]
float mSteering; // [ RANGE = -1.0f->1.0f ]
int mGear; // [ RANGE = -1 (Reverse) 0 (Neutral) 1 (Gear 1) 2 (Gear 2) etc... ] [ UNSET = 0 (Neutral) ]
// Motion & Device Related
float mWorldPosition[VEC_MAX]; // [ UNITS = World Space X Y Z ]
float mOrientation[VEC_MAX]; // [ UNITS = Euler Angles ]
float mLocalVelocity[VEC_MAX]; // [ UNITS = Metres per-second ]
float mWorldVelocity[VEC_MAX]; // [ UNITS = Metres per-second ]
float mAngularVelocity[VEC_MAX]; // [ UNITS = Radians per-second ]
float mLocalAcceleration[VEC_MAX]; // [ UNITS = Metres per-second ]
float mWorldAcceleration[VEC_MAX]; // [ UNITS = Metres per-second ]
float mExtentsCentre[VEC_MAX]; // [ UNITS = Local Space X Y Z ]
// Wheels / Tyres
unsigned int mTyreFlags[TYRE_MAX]; // [ enum (Type#7) Tyre Flags ]
unsigned int mTerrain[TYRE_MAX]; // [ enum (Type#3) Terrain Materials ]
float mTyreY[TYRE_MAX]; // [ UNITS = Local Space Y ]
float mTyreRPS[TYRE_MAX]; // [ UNITS = Revolutions per second ]
float mTyreSlipSpeed[TYRE_MAX]; // [ UNITS = Metres per-second ]
float mTyreSpeed[TYRE_MAX]; // [ UNITS = Metres per-second ]
float mTyreTemp[TYRE_MAX]; // [ UNITS = Celsius ] [ UNSET = 0.0f ]
float mTyreGrip[TYRE_MAX]; // [ RANGE = 0.0f->1.0f ]
float mTyreHeightAboveGround[TYRE_MAX]; // [ UNITS = Local Space Y ]
float mTyreLateralStiffness[TYRE_MAX]; // [ UNITS = Lateral stiffness coefficient used in tyre deformation ]
float mTyreWear[TYRE_MAX]; // [ RANGE = 0.0f->1.0f ]
float mBrakeDamage[TYRE_MAX]; // [ RANGE = 0.0f->1.0f ]
float mSuspensionDamage[TYRE_MAX]; // [ RANGE = 0.0f->1.0f ]
// Car Damage
unsigned int mCrashState; // [ enum (Type#4) Crash Damage State ]
float mAeroDamage; // [ RANGE = 0.0f->1.0f ]
float mEngineDamage; // [ RANGE = 0.0f->1.0f ]
// Weather
float mAmbientTemperature; // [ UNITS = Celsius ] [ UNSET = 25.0f ]
float mTrackTemperature; // [ UNITS = Celsius ] [ UNSET = 30.0f ]
float mRainDensity; // [ UNITS = How much rain will fall ] [ RANGE = 0.0f->1.0f ]
float mWindSpeed; // [ RANGE = 0.0f->100.0f ] [ UNSET = 2.0f ]
float mWindDirectionX; // [ UNITS = Normalised Vector X ]
float mWindDirectionY; // [ UNITS = Normalised Vector Y ]
float mCloudBrightness; // [ RANGE = 0.0f->... ]
} SharedMemory;
#endif // _SHARED_MEMORY_HPP_Users browsing this forum: No registered users and 4 guests
