Re: projectCARS
Postby lucasdiulbern » Tue 1. Sep 2015, 02:44
It worked!!!
Thank you for your help.
I had tested only one of the settings that you have posted.
Now that I've tested the second is that I understand exactly what you said.
I use the google translate to translate into my language and not always translates to perfection.
Thank you same
lucasdiulbern
Images: 20
Re: projectCARS
Postby upgraded » Fri 4. Sep 2015, 18:12
in my case all works fine. only the shutoff wont work.
upgraded
Re: projectCARS
Postby sirnoname » Fri 4. Sep 2015, 18:28
Yes, with the next update there is a solution.
Re: projectCARS
Postby vicpopo » Fri 4. Sep 2015, 20:21
Next xsim update ;) ?
Re: projectCARS
Postby GhostFace » Wed 9. Sep 2015, 21:21
Hi!!
Please, i need help, i cant get Project Cars running with my Buttkicker!!
I think my main problem is, that no connection to the game can be made, the Extractor cant seem to find the right .exe and so the plugin doesnt get activated!!
I use 64bit Project Cars Version i think thats a problem?!
PLEASE, can someone describe a step by step tutorial on how to get this solved?? I spent now nearly 4-5 hours and still stuck !!! :oops:
Thx!!
GhostFace
Re: projectCARS
Postby sirnoname » Thu 10. Sep 2015, 07:39
and you really read this post?
Re: projectCARS
Postby GhostFace » Thu 10. Sep 2015, 10:50
I got it working now, but it took me hours.... as for now, i got RPM working!! :)
But, i tried to get Gear Change Effect but no luck, there´s no input.... i also want to feel road bumps and suspension, is this even possible now, cause i cant find a proper effect for it?
Thx!
GhostFace
Re: projectCARS
Postby sirnoname » Mon 14. Sep 2015, 22:25
Vertical force available?
Re: projectCARS
Postby ariel1981 » Tue 3. Nov 2015, 04:36
GhostFace wrote:I got it working now, but it took me hours.... as for now, i got RPM working!! :)
Thx!
Hello. You can try the 27 effect (longitudinal Force)
Maximal value = 293848974
Threshold value = 20000
try that and tell me. Cheers
ariel1981
Re: projectCARS
Postby stazer » Wed 18. Nov 2015, 13:15
Hello,
All is good but movement is activate very long after action !!!
Ex: when i brake motion move front 5 secondes after ...
Did you have explain ?
I launch pcars with the solution explain
Launch with steam , version pcars 6.0
V5 plugin pcars x-xim plugins
memory is Activate in game
Cheers
stazer
Return to Project CARS
