Re: projectCARS
Postby sirnoname » Tue 2. Oct 2012, 16:20
Are you sure?
Here is the Link to discuss the API in projectCARS (registration and donation needed):
http://forum.wmdportal.com/showthread.p ... rs-SDK-API
Thread name: SDK-API
If there is no API (the dbox plugin will not help) we can close this attempt.
Re: projectCARS
Postby Roadster2 » Tue 2. Oct 2012, 16:25
Berney of * was collecting together information from as many manufacturers/suppliers etc. as possible in order to create an API that would cover multiple devices. This included motion systems, LCD panels and other accessories. I mention this in case it saves having to invent the wheel twice ?
Roadster2
Re: AW: projectCARS
Postby minikase » Tue 2. Oct 2012, 16:32
Sure! All simulator builders with interest in pCars are asked in this thread to give their needs for a comming API.
minikase
Re: projectCARS
Postby sirnoname » Tue 2. Oct 2012, 16:39
no Problem minikas,
then I will use the graphic driver for project cars ...
Re: projectCARS
Postby Roadster2 » Tue 2. Oct 2012, 16:57
Roadster2 wrote:* of * was collecting together information from as many manufacturers/suppliers etc. as possible in order to create an API that would cover multiple devices. This included motion systems, LCD panels and other accessories. I mention this in case it saves having to invent the wheel twice ?
Why has my post been edited to remove the name of the person collating all of the information together, and helping us all in the process ? If we're going to start getting political on this site then it's on a downward spiral !
Roadster2
Re: AW: projectCARS
Postby minikase » Tue 2. Oct 2012, 17:03
sirnoname wrote:no Problem minikas,
That sounds very good...so we can use our simulators soon without waiting for the API which could be nearly one year away.
minikase
Re: projectCARS
Postby sirnoname » Tue 2. Oct 2012, 17:04
No edit, only a modification of the commercial filter. We had some problems with different commercial shops and this are banned to not lead people to this places. You have point me to one shop with abusive material against me and this should not happen again.
In the future this shops are simple out of this forum.
So keep it simple and accept that bad influence should not apear in this forum again.
Re: projectCARS
Postby minikase » Thu 4. Oct 2012, 22:14
No chance to start pCARS dx9 with motiondriver...it freezes before the login-Frame :(
minikase
Re: projectCARS
Postby sirnoname » Tue 9. Oct 2012, 14:35
N problem to bring it running. A crash is good to get fixed.
However I need someone who do search the internet.
In a first view there are much ideas and tools like this one here:
http://forum.projectcars.ru/threads/ffbtweaker.160/
http://www.project-cars.fr/forum/les-pr ... tweak.html
With much informations we get a running plugin.
Re: projectCARS
Postby prodigy » Sat 27. Oct 2012, 09:20
Sorry for bumping this thread, but, did someone managed to get pCARS work with X-Sim?
Return to Project CARS
