DIRT RALLY PLUGIN AYUDA POR FAVOR  Topic is solved solved with post #22760
Postby Brianpaiz » Wed 6. Jun 2018, 18:04
HOLA A TODOS,
NO ENCUENTRO EL PLUGIN PARA EL DIRT RALLY, VEO MUCHA INFO DE COMO SOLUCIONAR LOS PROBLEMAS PERO NADA DONDE SE UBICA EL ARCHIVO.
SI ALGUIEN PUEDE DECIRME COMO LLEGAR A EL SERIA DE MUCHA AYUDA.
SALUDOS A TODOS
Brianpaiz
DIRT RALLY EL PLUGIN PARA TODOS!!  Topic is solved
Postby Brianpaiz » Sat 16. Jun 2018, 23:50
ESTE POST VIENE DEL USUARIO :arrow: spyderwash
SI LO SIGUEN TAL CUAL ESTA AQUÍ ABAJO, VAN A PODER HACER FUNCIONAR EL DIRT RALLY SIN PROBLEMAS
A MI ME FUSIONO PERFECTAMENTE !
SALUDOS
TIENEN QUE AGREGARLO MANUALMENTE, NO DE MANERA AUTOMÁTICA
extractor:
C:\Program Files (x86)\Steam\steamapps\common\DiRT Rally\drt.exe
plugin codemaster
call parameter steam://rungameid/310560
plugin uses standard codemaster no f1 2015 movements are best
C:\Users\.........\Documents\My Games\DiRT Rally\hardwaresettings
<motion_platform>
<dbox enabled="false" />
<udp enabled="true" extradata="1" ip="127.0.0.1" port="20777" delay="1" />
Brianpaiz
