Info plugin Flight Simulator
Postby Commodore » Sat 20. Feb 2021, 15:22
Hi all of you, I need your help to be able to use Flight Simualtor X with X-Sim.
I don't know which plugin to use (I read that FSUIPC must be used).
With Flight simulator X I don't know where to start, if in addition to using FSUIPC I should also use another plugin to paste in X-Sim.
I would like to use "Microsoft Flight Simulator X" with Xsim, for my 2DOF simulator.
To do this, do I have to use only FSUIPC or do I have to use a 2nd plugin as well?
Commodore
Re: Info plugin Flight Simulator
Postby sirnoname » Sun 21. Feb 2021, 01:16
Select msflightsim in X-sim, it will ask you for FSUIPC connection.
Postby Commodore » Sun 21. Feb 2021, 13:55
Ok thanks Sirnoname.
One question: this procedure is valid for Flight Simulator X and Flight Simulator X Steam edition?
Or maybe for the Steam version I have to do a different procedure?
Commodore
Postby sirnoname » Sun 21. Feb 2021, 14:08
Commodore, I told you in last post, that the X-Sim plugin is called MSFlightsim, and that this is using FSUIPC.
So I assume you did not read this?
For the support of Steam games etc., you must ask in the FSUIPC forum. MSFlightsim is only the connector to use FSUIPC with X-Sim.
Please read the manual.
Postby Commodore » Thu 1. Apr 2021, 17:49
Hello Sirnoname, is xsim also compatible with Microsoft Flight Simulator 2020?
Commodore
