Automobilista not working, every other game does
Postby rufeo » Fri 9. Dec 2016, 13:41
Hi guys,
I just downloaded Automobilista from Steam and I was trying to turn it on.
I cheked the forum and I saw that people made it work with Rfactor Plugin so I made this steps:
1) I copied Rfactor plugin into the Plugin folder of Automobilista.
2) Open extractor and set it up with the steam call parameter and Rfactor plugin
When I play the game, the seat remains static but there is not communication between Extractor and Converter (there is not telemetry).
I have lot of games working with XSIM such as Game Stock Car, Rfactor, Dirt 3, Dirt Rally and Assetto Corsa. Maybe do I have to update the Rfactor plugin to make it work?
Thank you and regards.
rufeo
Re: Automobilista not working, every other game does
Postby spyderwash » Fri 9. Dec 2016, 18:42
Copy plugin "xsimplugin.dll" folder
C: \ Program Files (x86) \ Steam \ steamapps \ common \ Motorist \ Plugins
in extractor controls wizard game
C: \ Program Files (x86) \ Steam \ steamapps \ common \ Motorist \ AMS.exe
steam: // rungameid / 431600
if you use win 10 checks that it is updated and installed
microsoft visual c ++ 2012/2013/2015
copia plugin " xsimplugin.dll" nella cartella
C:\Program Files (x86)\Steam\steamapps\common\Automobilista\Plugins
in extractor controlla wizard game
C:\Program Files (x86)\Steam\steamapps\common\Automobilista\AMS.exe
steam://rungameid/431600
se usi win 10 controlla che sia aggiornato e installato
microsoft visual c++ 2012/2013/2015
spyderwash
Postby rufeo » Fri 9. Dec 2016, 20:57
spyderwash wrote:Copy plugin "xsimplugin.dll" folder
Thanks for your help.
I did that and I also had to load an online profile to make it work ;)
rufeo
Postby alialf » Mon 2. Jan 2017, 19:48
I follow the steps but it does not work for me. help me please.
alialf
Postby spyderwash » Mon 2. Jan 2017, 20:34
I have no problems with the game you have followed the instructions are sure you have made the right plugin
spyderwash
Postby alialf » Mon 13. Mar 2017, 17:51
I can not make it work.
alialf
Return to General Chat
