Problem with logitech g27 and race07
Postby Monaco85 » Mon 17. Mar 2014, 09:52
Hey, i have a problem with my logitech g27 steering wheel race 07 and x-sim.
I have installed the wheel on windows7 and installed the logitech profiler. Now my problem is when i start race07 over x-extractor. The wheel works for 2 minutes. But after that it doesnt react anymore. Are there some setti gs to do in x-sim? Do i have to close the logitech profiler?
Monaco85
Re: Problem with logitech g27 and race07
Postby sirnoname » Mon 17. Mar 2014, 10:48
X-Sim is independent from any input device. There is a box in the extractor on the right side.
Look for USB disconnects because of other powerfull devices which can make noise/errors to USB.
Postby Monaco85 » Mon 17. Mar 2014, 10:51
Its only a keyboard mouse, arduino and wheel.
Shell i disable everything in the box right?
Maybe i need a active hub for the arduino ?
Monaco85
Postby sirnoname » Mon 17. Mar 2014, 11:28
You shall deselect the input device if there is one selected (normaly this box say disable).
Yes, check the arduino step by step. Remove the H-Bridge and use the arduino only for a test of 2 and more minutes.
Postby Monaco85 » Mon 17. Mar 2014, 12:11
In x-extrator there are all enabled. This is wrong, right ?
Monaco85
Postby sirnoname » Mon 17. Mar 2014, 12:17
What all? It is one box!
Postby Monaco85 » Mon 17. Mar 2014, 12:27
The extractor was searching to begin for available driver. And found a list of 20 driver. And they are all active. But for the most. I dont know what they are.
This evening i can take a picture
Monaco85
Postby Monaco85 » Mon 17. Mar 2014, 18:46
here u see right These plugins i dont know
and left there is my wheel
and what are These Input Settings ?
Monaco85
Postby sirnoname » Mon 17. Mar 2014, 19:13
disable the dxjoystick plugin checkbox on second screen right!
You made pictures from/you talk about converter an not from extractor.
Postby Monaco85 » Mon 17. Mar 2014, 19:20
your right. Converter sorry.
I disabled everything But no change.
I drive 1 minute then the wheel doesnt react anymore.
Without X-Sim Everythin works fine. Arduino was active. But no Pololu
Monaco85
Return to General Chat
