Problem with logitech g27 and race07
Re: Problem with logitech g27 and race07
Postby dennisnojack » Tue 18. Mar 2014, 17:38
If the Arduino only send to Popolu only the output pin from Arduino to Popolu.
If the Arduino send/receive to/from Popolu the output/input from/to Arduino to/from Popolu.
Am i right sirnoname?
Read the datasheet of the opto-isolator you want to buy.
dennisnojack
Postby sirnoname » Tue 18. Mar 2014, 19:00
Ah, you are using a pololu H-Bridge and not a pololu controler! That is new.
After the arduino must be a optocupler to avoid power noise to the arduino or to the shield contact. Only in some low power case this must not be equiped.
Postby Monaco85 » Tue 18. Mar 2014, 21:03
explain me please.
I testet now with 2 PCs. One pc with arduino and one with the game and the wheel. The Problem is the same.
This cant be a problem from the USB because i use a nother pc.
I dont know whats wrong.
But its only when i play with X-Sim.
Monaco85
Postby sirnoname » Tue 18. Mar 2014, 21:25
The electrical noise of the whiper motor is high. If you connect this circuit with your arduino you make influences to the ground connection and produce USB comunication problems (disconnects).
Postby Monaco85 » Tue 18. Mar 2014, 21:40
Influence to my ethernet ? I dont think so.
The only connection between Logitech and Ardiuno(And Viper) ist a Ethernet Cable trough a Switch :-)
I testet with my old logitech Momo and it works. It will not crush.
Now i think my G27 is smashed.
Monaco85
Postby dennisnojack » Tue 18. Mar 2014, 21:44
And your ethernet-cable is grounded.
PC1- ethernet ground
PC2 - ethernet ground
Switch - ethernet ground
Result = Ground of Pc1, Pc2 and Switch is the same.
dennisnojack
Postby Monaco85 » Tue 18. Mar 2014, 22:19
No. Ethernet has a inverted signal, no ground. In this point u are wrong.
And i sniffed with wireshark. There are no unknown or unreadable packages.
I bought a new Logitech g27. In two days i will tell you more.
As i said. Because of testing on 2 Pc's iam nearly sure that the problem dont comes from my pololu.
@sirnoname. Iam right with you that the motors can produce influence on the USB.
But noch on USB on an other PC.
This would be Magic :-)
Monaco85
Postby dennisnojack » Wed 19. Mar 2014, 00:12
Thats not what i mean with ground.
All your PCs use the same ground. Because your ethernet cable is shielded (ground).
I mean not to short a circuit.
dennisnojack
Postby sirnoname » Wed 19. Mar 2014, 11:27
You can start the extractor with a nojoystick parameter to avoid touching direct input completely:
http://www.x-sim.de/manual/source_sdk.html
You will not see your stick in the box if you use this parameter.
Postby Monaco85 » Wed 19. Mar 2014, 11:53
I disabled all plugins. I think this has the same effect.
I will tell you if it works with the new g27.
It makes me hopeful that it will work. Because with my logitech momo everythin work fine.
Monaco85
Return to General Chat
