PSU and car battery in parallel
Postby Bergison » Tue 10. Dec 2013, 21:37
Hi everybody,
some advices in this forum regarding power supply solutions is to connect a car battery in parallel to a psu.
I have two 12V - 40A PSUs: http://r.ebay.com/zPzf45 and planned to power two 12V 30W wiper motors from each psu (four motors total).
As I found out during initial testing, the psu kind of shuts down after some turns of the motor!? :?
After waiting a few minutes, the motor turns again, but not for long. Since the psu was rather cheap, I suspect it to be the problem.
I still have a 60Ah - 320A car battery lying around and was wondering if it might help to use it in parallel with the psu, as suggested some times in this forum.
My questions:
- doesn't the battery overcharge or something with a 40A psu?
- do I have to ground the battery, or is this done via the psu ground?
Thanks for your help and sorry if my questions sound stupid, but I'm a complete noob regarding electrics... :roll:
( This is my project: http://x-sim.de/forum/viewtopic.php?f=37&t=1310 )
Bergison
Images: 20
Been thanked: 9 times
Re: PSU and car battery in parallel
Postby prodigy » Tue 10. Dec 2013, 22:09
That's odd, I have run two wipers with one cheap 12v 30A PSU, so you should be running two wipers with even stronger 40A PSU. Does the same thing happens with other PSU?
Postby Tombo » Tue 10. Dec 2013, 22:20
Without load? I used 15A psu from pc worked for testings. I can recommend you hp dsp 600 pb server powersupply vewry cheap 19,99€ on ebay, easy to mod and i run two wipers with one power supply.
http://www.ebay.de/itm/HP-Server-Netzteil-DPS-600PB-B-fur-DL380-G4-DL385-G1-Grade-A-ESP135-321632-001-/321200103023?pt=PC_Netzteile&hash=item4ac9049e6f
Tombo
Images: 36
Postby vicpopo » Tue 10. Dec 2013, 22:50
Hi Bergison,
One of the many discussions about car battery paralell to a psu.
http://www.x-sim.de/forum/viewtopic.php?f=43&t=246&start=120&hilit=Tronicgr+car+battery#p8711
It's surprising if the psu could have problem without load ! Agree with Tombo!
Postby Bergison » Wed 11. Dec 2013, 22:23
Thanks for your replies! You were right - the psu wasn't the problem! It was the pot and a mistake by myself in the arduino firmware. I was able to repair the pot, it shows its correct position * But I'm still fighting with the coding of the firmware and asked for help there:
http://x-sim.de/forum/viewtopic.php?f=39&t=723&start=260
Bergison
Images: 20
Return to Power supplies
