power source from a computer question
Re: power source from a computer question
Postby floriske » Sun 26. Aug 2012, 17:24
Lol! Actually just killed one of the 30A psu's testing my new motors @ 27, 5A (no white smoke though ;) )
Hope I can fix it, but already ordered 2 of these instead:
http://www.ebay.nl/itm/12V-45A-600W-Swi ... 5ae92a13a5
Gives me a bit more overhead :D
floriske
Images: 96
Postby ferslash » Mon 27. Aug 2012, 16:51
Ups!!! i got to be carefull,
i was searching for a dedicated power supply like the ones florinke mentioned, but... they cost more than $100 usdlls here in mexico it is crazy...!
and a finnal question.... so no one is using a computer psu to feed the motors??? no one? i mean... it is almost sure that if i use a psu i will burn it?
best regards
fer
ferslash
Postby Roadster2 » Mon 27. Aug 2012, 17:03
It's possible to use a PC power supply, particularly if that's all you have access to within a reasonable price. The power supply requires a connection to a mainboard in order to work but this can be cheated by connecting together a couple of the cables. There is plenty of info on this available from a web search.
If you can, get one of the later power supplies with dual rail or quad rail +12V lines. Just check the specifications of current ratings on the +12V lines and get as high a current capability as you can.
Good luck with your search.
Roadster2
Postby telfel » Mon 27. Aug 2012, 18:50
hi
I have a couple of server power supplies, which are easy to convert and can give 12 volt @ 50amps upwards, depending on the power supply.
these power supplies are cheap and available on ebay.
links for more info
http://www.rcgroups.com/forums/showthread.php?t=1292514
http://www.rcgroups.com/forums/showthread.php?t=1005309
regards Terry
telfel
Images: 54
Been thanked: 9 times
Postby floriske » Mon 27. Aug 2012, 19:50
@ferslash: why not order them from China on ebay? Ok, takes a few weeks for them to arrive, but saves a lot of money as well.
floriske
Images: 96
Postby ferslash » Mon 27. Aug 2012, 19:53
good point...
i will check prices
fer
ferslash
Postby Pablo » Mon 27. Aug 2012, 20:18
Hello, I'm using a 650W PC power supply, my simulator is the type Frex, just move the seat and weight 70 kg., If the balance is right, it works great
In my country the cost of other sources is very high, so I decided to use a PC power supply ...
Regards
Pablo
Images: 2
Postby ferslash » Mon 27. Aug 2012, 21:34
Pablo:
How are you using your psu? one psu 650w connected to two motors or one psu 680w to each motor?
best regards fer
ferslash
Postby motiondave » Mon 27. Aug 2012, 23:11
I used to run computer PSU's when I had wipers, but they were spare PSU's I had. They originally only cost me $30 each.
However, the PSU's only really put out 18 amps at 12v. So I had one per motor. This worked ok, but they would still trip out from time to time.
Here in Australia, I decided to buy a proper benchtop power supply via ebay or when they are on special at radio ham shops and electronic shops.
That and I didnt have to chop up a perfectly good computer PSU.
The neater option is 2 power supplies.
The cheaper option is one power and one car battery in parallel.
Now with the big worm gear motors, I just run one 13.8v 32 amp power supply and one car battery rated at 405 CCA in parallel. Plenty of current for big spikes.
Floriske is on the right idea about 2 BIG power supplies for his big motors.
Postby Pablo » Mon 27. Aug 2012, 23:35
Hi Ferlash, one psu 650w connected to two motors :roll: and still works ... must be of good quality PSU !
Regards
Pablo
Images: 2
Return to Power supplies
