Cheers,
Mike
Battlestar wrote:Thanks Thanos for your reply.
Its re-assuring that a second computer is not a requirement and I appear to have enough computing power available, but it sounds as if a crash of the computer might result in a real crash of the simulator. I guess that's why an emergency stop switch is a good thing to have. And yes I'm using a NON-intelligent controller (velleman + Sabertooth). I think it sums me up - Non-intelligent!
Cheers,
Mike
tronicgr wrote:Well, NON intelligent means that it relays to the computer "brains" to guide its output signals and its not able to hold position of the motor by its self.
An intelligent controller is reading the desired position from the computer only and does all the positioning using its own "brains". Nothing catastrophic will happen to an intelligent controller if losses contact with the computer, worst case it will HOLD the motor the the last commanded position. Won't let the motor spin out of control.
I don't want to discourage the use of such non-intelligent systems but I think I would prefer to have higher safety standards first of all. Especially with something like a full motion simulator that you are sitting in it.
tronicgr wrote:Examples of such controllers without brains are:......... Velleman .
examples of controllers with brains are:...... A*******B, J******2, S**5 .... and many more...
tronicgr wrote:I was just making a point that Velleman are NOT intelligent Controllers!!! They are just input-output interfaces!!!
