PC setup
Re: PC setup
Postby tronicgr » Fri 20. Jul 2012, 14:11
Do you have any idea how terrible update rate these input-output interfaces have? Go ahead if you want to make a slow moving Boing747 simulator...
Eventually we have to move on to actual working intelligent controllers for real and accurate simulation. That's what all is about. Simulation!! NOT arcade machines!! And saying that I share Sirnoname's opinion too!
Re: PC setup
Postby motiondave » Fri 20. Jul 2012, 15:00
Well currently the JRKS are good, but the Arduino codes need to be sorted, and your controller look promising, but i am seeing issues.
So what else can we use then?
I would like to move up to 24 and even 240 v motors.
What do I use then?
Re: PC setup
Postby Roadster2 » Fri 20. Jul 2012, 15:14
Plus 1 to Dave's comment.
I am currently investigating the use of AC motors controlled by Frequency Inverters. I have yet to sort the interface between the PC and the Frequency Inverters. While the connections between the Frequency Inverters and the motors are straight forward what to use to control the Frequency Inverters is looking to be a bit more of a problem.
Roadster2
Re: PC setup
Postby tronicgr » Fri 20. Jul 2012, 15:23
motiondave wrote:I would like to move up to 24 and even 240 v motors.
What do I use then?
How about this?
AMC644USB + Digital/Analog Opto-isolation board for Inverter
I was two optocouplers sort but I tested it, and it works! Soon to be connected to 220v inverters... ;)
Re: PC setup
Postby Roadster2 » Fri 20. Jul 2012, 15:30
Hi Thanos
Please, keep us updated :)
Roadster2
Re: PC setup
Postby motiondave » Fri 20. Jul 2012, 15:42
Nice, get it sorted and I will use it....
Re: PC setup
Postby tronicgr » Fri 20. Jul 2012, 16:07
Roadster2 wrote:Please, keep us updated :)
I'll be posting updates on my blog...
http://motionsim.blogspot.com/2012/07/ac-motor-driver-opto-isolation-interface.html
Return to Forum & Website
