Cannot login using my old username & password
Want to contact an administrator? Please use pm or post here.
Postby koko » Sun 9. Nov 2014, 20:29
hi, i did not use my simulator for 6 weeks because i was on holiday, when i got back from holiday and tried to use my race simulator, i found that i could not login with my normal username and password. i have had to re-register with a new username and password. Does this mean that i have to re-donate in order to get my simulator up and running again? here are my old login details:
username = kokopelli
password = 4CWWTBPA
X-Sim Key = 5359534B11
PC id for X Sim Actitvation = 711030860-030860070-860070538-070538280
Thanks for your help, Andy.
koko
Re: Cannot login using my old username & password
Postby sirnoname » Sun 9. Nov 2014, 21:12
no, use simple your new login. Users with zero posts get deleted from time to time (=spambots).
Key will work with any login name.
By the way: if you have donated, you can enable the offline mode, than you do not need any forum account ;)
Simple use X-Sim registry cleaner in the /other stuff directory for fresh startup, go offline and start the extractor. Then enter key and enable the offline mode in the settings menu (checked).
Restart and you do not need any login.
cu
Postby koko » Mon 10. Nov 2014, 00:47
Hi, thanks for your reply, i did exactly what you said, and my simulator now works perfectly. Thanks for your help, Andy.
koko
Return to Moderator or admin general contact
