Ne02005´s simulator 2Dof wipermothors AMC1.6+Pololu Hbridge
Topics and questions about other X-Sim compatible hardware
Postby ne02005 » Tue 14. Aug 2012, 19:36
Hi guys, I´m posting my new work on this new forum. 8-)
I wish had a X-Sim 3 Supporter key!!! :D :D :D :D :D :D :D
It´s a full motion Sim (Seat, Wheel and Pedals) will move. Not only the chair...MORE REALISM!!!!
All this have a Logitech G27, a Full Dashboard with Rpm, Speed, water, oil, temp.. etc and a Tablet with Information!!!!
I´m with all this project about 2 years.. in the old forum I was very active user.
The electronics is Thano´s AMC 1.6 + Pololu mini Hbridge.
By ne02012 at 2012-07-04
By ne02012 at 2012-08-14
I need to fix the motors with the frame....
bye
ne02005
ne02005
Re: Ne02005´s simulator 2Dof wipermothors AMC1.6+Pololu Hbri
Postby vittobrambi » Tue 14. Aug 2012, 20:31
It looks like a very nice project.
I have a question: what are the suspensions for? Are the intended for 3rd vertcal axis?
vittobrambi
Postby ne02005 » Tue 14. Aug 2012, 22:32
vittobrambi wrote:Hi,
Thanks!, They are just for add a little more of movement while playing. In a future will be 3 Dof.
ne02005
ne02005
Postby motiondave » Wed 15. Aug 2012, 02:09
yeah...looking good....
Postby tronicgr » Wed 15. Aug 2012, 18:15
This looks good.
Wiper motors?
Postby ne02005 » Wed 15. Aug 2012, 19:25
tronicgr wrote:This looks good.
Wiper motors?
Yes! why you say that?
You think that not move it?
The frame is very light, is made with car tail pipe... and is perfectly balanced.
bye
ne02005
ne02005
Postby tronicgr » Wed 15. Aug 2012, 19:39
Just asking. It will work fine.
Just some notes:
1. The frame will become unbalanced when leaning to various angles other than flat, meaning more stress to the motors on the extreme positions.
2. You should try placing some weight hanging lower than the COG to counter-balance all the weight that is on top of the COG.
3. The motors should be setup with KP higher than 10 for the Proportional drive to be able to hold positions without too much undershooting or overshooting.
I guess for your platform all this is matter of experimenting to see what suits you better. And since you built it yourself you can figure out what modifications should be done to improve it, that's the good part about DIY.
Postby ne02005 » Wed 15. Aug 2012, 21:05
tronicgr wrote:Just asking. It will work fine.
Just some notes:
OK Thanos, I have to try... Maybe I use 4 motors with 2 bridges at paralell for more power.
Tonight, I´ll fix the motors to the frame, and I´m waiting my 2nd Pololu bridge for testing.
I hope it works!!! I´m with this SH*T over 2 years...
bye
ne02005
ne02005
Postby ferslash » Sun 19. Aug 2012, 07:15
looking good your project, i got a question.
As far as i understood, the pololu card cand handle all the job, so, why using amc+pololu cards?, what is the result of this convination?
best regards from mexico
fer
ferslash
Postby ne02005 » Tue 21. Aug 2012, 15:39
ferslash wrote:looking good your project, i got a question.
fer
The Amc 1.6 interface with PC, and the Pololu Hbridge drives de motors.
ne02005
ne02005
Return to Other X-sim compatible hardware
