ne02005 wrote:prodigy wrote:It's going smooth..
Have you tested it with weight on, yourself on the seat?
I need to upgrade the power supplies or maybe use a car battery.....
Or use both paralel !
ne02005 wrote:What Coud it be??
I had to change "intensity value on the axis) on the math Output setup to 30 %.... If I leave at 100 (default) the motors shake a lot...
it coud be a KP settings? I have 5:5
KP settings? Where are those, I can't remember *.
my motor should be "too used", i opened the motor and i saw sings of to much "wear" signs...
The motors are very HOT on load.. after 15 minutes, I can`t touch them...
Return to Other X-sim compatible hardware
