SCN5 / SCN6 Hardware Thread
Postby sniegavirs » Fri 19. Apr 2013, 12:03
Maybe www.farnell.com can help you with this.
Prices are good and shipping is fast! ;)
sniegavirs
Images: 16
Postby seppel » Fri 19. Apr 2013, 16:29
thx sniegavris for useful link, but i need to know the exact classification of the plugs.
here is a closeup pic of the plugs
1427
seppel
Images: 34
Postby seppel » Sat 20. Apr 2013, 00:18
thx for your detailed investigation.
i will check your links and report the progress in this case
thx for great research
best regards
seppel
seppel
Images: 34
Postby sirnoname » Sat 20. Apr 2013, 11:11
Updated the first page with connector informations.
Postby Hmaia » Mon 10. Jun 2013, 21:44
I have access to a couple of used SCN5's. They look to be in very good shape. Anyone with experience with used SCN5's? What should I look for in order to avoid a lemon>?
Hmaia
Images: 22
Postby sirnoname » Mon 10. Jun 2013, 22:36
Nearly undestroyable. Somtimes the pin from the motor axis get broken but it can be demounted and exchanged.
Postby Hmaia » Tue 11. Jun 2013, 01:54
Thank you sirnoname, for the prompt response. I have ordered both, will be here this week.
Hmaia
Images: 22
Postby Hmaia » Sat 15. Jun 2013, 00:41
Would this usb to rs485 work for SCN5?
http://dx.com/p/usb-2-0-to-rs485-422-converter-201897
Thank you again
Hmaia
Images: 22
Postby sirnoname » Sat 15. Jun 2013, 06:35
It seems to be a full duplex adapter.
This is dangerous because I cannot read how it work with half duplex. Most of the full duplex adapter make bridges and have a echo on the datalines.
So better not use this adapter.
Postby Hmaia » Tue 18. Jun 2013, 22:23
I have a schematic for connection of the SCN5's.
I am planning on using three independent circuits, one for each actuator, using the following 24V 3A power supply and Devantech USB to RS485 converters. Each circuit will have its own kill switch.
http://www.ebay.com/itm/DC-24V-3A-Switc ... 3f0c11d587.
I would greatly appreciate any comments/suggestions, as I want to have a nice clean build.
How many watts for the Zener diode?
1691
Hmaia
Images: 22
Return to Actuators
