4 wiper motors with a Thanos's AMC1.5
Postby wolfy80 » Fri 7. Jun 2013, 15:53
hello everyone
i've reading a lot of posts in this forum and I always study my project.
i have a Thanos's AMC1.5 bord and i want to use 4 wiper motors with 2 dual H-bridges for my motion simulator.
i don't need the screen.
is that possible ? i think , for the hardware yes , but i'm not sure for the firmware.
did you confirm it?
thanks all
wolfy80
Re: 4 wiper motors with a Thanos's AMC1.5
Postby RafBR » Wed 7. Aug 2013, 16:37
I think you will need two amcs, one for each 2dof
regards!
RafBR
Images: 24
Postby ferslash » Wed 7. Aug 2013, 17:21
it depends on how do you want the wippers to work... if you are planning that the 4 wipers "lift" the weight of the sim (as in a 6dof platform) i have asked the same question and the answer is not... you need bigger motors.
wiper can only deliver enough force to "push" or change your equilibrium, not to actually "lift" weight, since they are weak.
if your design needs to "lift" weight you need bigger motors
best regards
fer
ferslash
