Original Rock’n’Ride (RnR) Interface substitute
Postby whoismrp » Tue 22. Jan 2013, 13:23
Hi There, Hopefully I've posted in the right place !
I have a Rock’n’Ride Simulator with the original Interface and unfortunately the PC that ran it was given to someone to fix (before I obtained it) and never returned. I have the original drivers and game that I'm fairly sure ran on a Windows XP machine . I setup a PC Running Windows 7 and installed X-Sim and used sirnonames instructions viewtopic.php?f=45&t=376 to try and configure the use of the original Interface but with no success in getting it to work. From reading further it appears people have had more success with the RnR 1.3 USB Interface though I cannot find a list of Components to build the board and the link in the Hardware section only took me to 2 images http://x-sim.de/manual/rnr_1_3.html .
I was hoping that either someone could point me in the right direction to getting the schematics with list of components etc to build one or if anyone has other recommendations on the best kind of controller to use for the Simulator ?
Thanks !
whoismrp
Re: Original Rock’n’Ride (RnR) Interface substitute
Postby cyber » Sat 16. Mar 2013, 23:29
Stückliste RnR USB Interface 1.3:
IC1 www.mercateo.com Pic 16C745 mit beschribenem Inhalt
IC2 Reichelt: "ST 24C02 MN" 24C02 SMD (SO8) EEPROM von ST (oder Vergleich)
LM7805 Reichelt: "µA 7805" Spannungsregler LM 7805 CT (oder Vergleich)
T1-T8 Reichelt: "BD 649" BD649 oder ähnlich (oder original TIP122)
D1-D8 Reichelt: "1N 4005" 1N4003 oder 1N4005 (oder Ersatztyp)
C1-C2 Reichelt: "NPO-G0805 22P" 22pF SMD Kondensator Baugröße 0805
C3 Reichelt: "X7R-G1206 100N" 1µF SMD Kondensator Baugröße 1206
C4 Reichelt: "SM 100/16 RAD" 100µF Elko Kondensator mind. 16V
C5 Reichelt: "SM 10/16 RAD" 10µF Elko Kondensator mind. 30V
C6-C7 Reichelt: "X7R-G0805 100n" 100nF SMD Kondensator Bauform 0805
R1-R8 Reichelt: "SMD-0805 47,0K" 47 KOhm SMD Widerstand Bauform 0805
R9-R11 Reichelt: "SMD-0805 56,0K" 51 KOhm SMD Widerstand Bauform 0805
R12-R15 Reichelt: "SMD-0805 1,00K" 1 KOhm SMD Widerstand Bauform 0805
R16-R18 Reichelt: "SMD-0808 100" 100 Ohm SMD Widerstand Bauform 0805
R19 Reichelt: "SMD-0808 1,50K" 1,5 KOhm SMD Widerstand Bauform 0805
R20-R21 Reichelt: "SMD-0808 4,70K" 4,7 KOhm SMD Widerstand Bauform 0805
R22-R29 Reichelt: "1/4W 5,1K" 5,1 KOhm Widerstand Stecktechnik
Quarz 6MHz Reichelt: "6-HC49U-S" oder "6-HC18"
Kabel 5 Meter Reichelt: "AK 672/2-5,0" USB 1.1 Anschlusskabel 5m A auf B
Con1 15pol Sub-D (z.B. aus Gameportslotblech)
Powersupply AT, ATX oder einfaches Netzteil 12V
mit mindestens 4-5 A
Option:
9 Reichelt: "SPC M3X6" M3 Plastikschrauben
9 Reichelt: "SPC M3" M3 Plastikmuttern
1 Reichelt: "GS 28" IC Sockel 28 polig zum Firmwaretausch
Con2 Farnell: oder aus altem Board
Con3 Farnell: oder aus altem Board
cyber
Postby sirnoname » Sun 17. Mar 2013, 11:09
Do someone have the original zip file with all details?
Please post here!
Postby cyber » Sun 17. Mar 2013, 12:19
i m also looking for Infos !
cyber
