I need some help?
I need some help?
Postby MattyB » Sat 8. Dec 2012, 12:21
Not sure where to post my question so I appologise in advance if im in the wrong area...
I purchased a second-hand Frex Simcon Motion System with all the bits and pieces, I have read all I can about using x-sim software and have ordered two RS485 adapters and expect them here in Australia within a couple of weeks.
In the interim, I think Ive set up my rig and actuators up correctly, Ive powered them up and very solid non-moving state is evident.
Question- can someone who knows, please explain what connection I should have running directly from the SimCon Base to the PC?
I have the cable end being a PS2 type connector!
Have I received all cables or am I missing a PS2 to USB converter cable or something?
Really not sure on what I should have there, Ive Googled and been to the FrexGP forums but that guy over their is a muppet, he deleted my question...
Any help would be great.
Regards,
MattyB
Regards,
MattyB
MattyB
Images: 5
Re: I need some help?
Postby MattyB » Sat 8. Dec 2012, 13:45
Ok, ignore above post...
I have just searched and found that I need a SimCon Base (which I thought I had), I have the SimCon Motion that plugs into the base...
Now, Im not prepared to spend more money in the Frex shop as I have a reserved opinion on how they do business!
Can someone best direct me to an easy step by step instruction on how to transfer to X-Sim and what parts ill need?
Thanks for your help...
MattyB
Regards,
MattyB
MattyB
Images: 5
Postby motiondave » Sat 8. Dec 2012, 14:11
you are in the right area, but I will have to let another member whom has had experience with these actuators help you.
Postby yokoyoko » Sat 8. Dec 2012, 15:16
Did you look at this thread?:
http://www.x-sim.de/forum/viewtopic.php?f=44&t=58&p=255&hilit=scn5#p255
I'm not a Frex expert but think this topic fits to replace a "simcon base".
Best regards
yoko
Postby sirnoname » Sat 8. Dec 2012, 16:17
The hardware box was not open source and did not get any support so it is completely removed.
Postby MattyB » Sun 9. Dec 2012, 02:09
yokoyoko wrote:Did you look at this thread?:
Best regards
yoko
Thanks guys for your help!
Thanks yokoyoko, great link to get me going!
Ive just come in this morning and powered up my AC Power Supply and I have no LED showing...
Im searching now for a replacement supply any tips with the right one for the job?
Regards,
MattyB
MattyB
Images: 5
