Yaskawa VS Mini inputs?  Topic is solved solved with post #25004
Postby DanielW » Sun 5. Sep 2021, 12:02
Hi! im new at this forum and i have planned to build a motion simulator for the first time.
Because my economy at the moment isn't that good my goal is to build it mostly with used parts from scrapheaps and such.
I know its quite a challenge but also a lot of fun.:)
I have gathered some Freq drives so far and they are 2 Yaskawa VS Mini and one Vs Mini J7. The plan is to build a 3Dof or maybe 2Dof with tractionloss because the setup is mostly for car simulation. The problem is that i have very basic knowledge about this drives. I will use a Arduinio R3 as a "PLC" and build Or buy some basic circuit to convert the pwm signals to 0-10v freq and optocouplers for directions as some other builders have done before. My question is how exactly do i connect it to the VFD's input? I will post a picture of the drive schematic and inputs.
From what i understand you must trigger the inputs with a signal from the VFD voltage to output by external optocoupler transistors and activate the inputs for direction of motor. On other brands for example the Allen Bradley they have a 24Vdc output that triggers this but i dont see how it can be done with the yaskawa VFD? can i use the S1-S2 for this or how does it work?
Wiring
DanielW
Re: Omron VS Mini inputs?
Postby DanielW » Sun 5. Sep 2021, 12:18
49174916 Some pictures of the electronics gathered so far
DanielW
Re: Yaskawa VS Mini inputs?
Postby DanielW » Sun 5. Sep 2021, 17:39
Can anyone help me? I want to know If it will work or if I have to get other VFD's?
DanielW
Re: Yaskawa VS Mini inputs?  Topic is solved
Postby DanielW » Sun 5. Sep 2021, 19:35
I think i found it in the manual i downloaded. I missed out the part where the control circuit inputs.
DanielW
