Noise on power supply !
Postby kbssa » Wed 3. Oct 2012, 17:07
Hi guys !!
I am having a problem with my two power supplies (12v 16A each).
I made a 2dof simulator (SFGT) with wiper motors and tronic's AMC 1.5 and Hb 1.2, the problem is that when I turn on all the stuff, the power supplies starts to make a noise and in both motors too, but if I turn on just one power supply there is an almost inaudible noise.
The noise is higher when the two leds of the h-bridge are turned on at the same time !
There is not way to play with that noise in my ear.
I think maybe the PWM frequency that is causing the problem, but I am not sure.
If someone knows what is causing the noise or have any suggestions to eliminate that noise from hell , please let me know !!
Thank's
kbssa
Images: 16
Has thanked: 5 times
Re: Noise on power supply !
Postby tronicgr » Wed 3. Oct 2012, 17:24
Sounds to me like short circuit of the motors through their housing... You need to do some isolation work there...
Postby kbssa » Wed 3. Oct 2012, 18:41
tronicgr wrote:Sounds to me like short circuit of the motors through their housing... You need to do some isolation work there...
Hi tronic !
I would say it is not short circuit of the motors through their housing, because I isolated them and I did some continuity tests with my multimeter and they are not connected through GND.
I was thinking maybe one power supply is transmiting noise to the other through the AC line. What do you think about that ? is that possible ?
And waht do you think about the PWM frequency is causing the noise ?
I forgot to say that my power supplies are switched ones.
Thanks for replying man !
kbssa
Images: 16
Postby kbssa » Thu 4. Oct 2012, 15:53
up !
kbssa
Images: 16
Postby fooons » Thu 11. Oct 2012, 21:57
kbssa wrote:up !
Did you solved the problem of noise?
Motors or power supply, I think you should discard one by one.
Regards fooons
fooons
Postby kbssa » Thu 11. Oct 2012, 23:05
No, I did not.
I tried to turn on only one side of hbridge, but no success.
I am almost sure that the noise is caused by the pwm frequency.
I will put the 22mhz crystal to see if noise go way !
thanks for replying man !
Regards,
Bruno
kbssa
Images: 16
Postby fooons » Thu 11. Oct 2012, 23:18
Ok,
I use 22 crystal on AMC 1.5 and no noise for me. Let's discarding things and do a diagnostic. Always is interesting solve this kind of problems, maybe others can have same someday. ;)
Regards fooons
fooons
