BTS7960 H- Bridge  Topic is solved solved with post #18213
BTS7960 H- Bridge
Postby Moppi » Mon 30. Nov 2015, 22:33
Hallo,
I like to Build 2 dof seatmover Unsinn the fantastic description by sironame.
Is it possible to use the BTS7960 h- brigde with arduino and x sim .
Im confused the BTS7960 Needs on more cable als Showmaster in sironames Tutorial.
Here the Description
[url][/http://www.instructables.com/id/Motor-Driver-BTS7960-43A/url]
Can someone help.
Uwe
Moppi
Images: 5
Re: BTS7960 H- Bridge
Postby sirnoname » Tue 1. Dec 2015, 08:41
no
Postby Moppi » Tue 1. Dec 2015, 09:02
Hi sironame,
Must i use this Bridge ?
http://www.ebay.de/itm/Dual-VNH2SP30-St ... SwYHxWMJ1r
Moppi
Images: 5
Postby adrianovrm » Tue 1. Dec 2015, 15:38
Yes , l can you this brigde with arduino , it controls motors a bit diferent than other brigdes,let me try explain. l will suposed you know a bit programming at arduino ok ?
Look : you have vcc pin ( let it free), GND (Connect with arduino GND) , IS pins ( let it free, no connect) , l_EN AND E_EN ( connect it together amd take a arduino pin to control it , if enable or not the motor, l dont remenber now if it is active at low or high levels, you will have to test. And now, the most importants pins, L_PWM and R_PWM, this two pins wil control both speed and cw/ ccw rotation path. l ll explain :
With L_PWM = 0 and R_PWM = 255 motor will run full speed for cw, with L_pwm 255 and r_pwm =0 will have fill speed for ccw. with L_pwm= 127 and r_pwm = 0 will have half speed for ccw. did you understand ?
adrianovrm
Postby adrianovrm » Tue 1. Dec 2015, 15:42
but, l probably wil not work with the default code f or arduino, cause it controls this diferent way .. you need to adapt the arduino code to make it work .
adrianovrm
Re: BTS7960 H- Bridge  Topic is solved
Postby sirnoname » Tue 1. Dec 2015, 19:23
For people which do not know H-Bridges, and have no knowlege about wiring them, it is better to use a polollu interface which comes with a bridge mounted to the usb interface and which is more professional in handling.
Postby Moppi » Tue 1. Dec 2015, 19:32
You are right sironame,
But it is my First time using programmable mikrocontroller. Finde es spannend.
So i have to learn and i think the bought h- bridges are not so Bad :?:
My budget is not so big
I have read about polollu it seems to easy and expensiv
Jedoch wenn ich mir noch 8 verschiedene Bridges kaufe ist polollu vielleicht günstiger :)
Lehrgeld learnmoney??
I am an newbie
Moppi
Images: 5
Postby Moppi » Wed 2. Dec 2015, 00:55
Hallo sironame
Ist pm möglich.
Moppi
Images: 5
