Need help please
Need help please
Postby nave » Sun 23. Mar 2014, 07:40
Hey guys,I am trying to make my own simulator.I have the simulator built but i do not know how to wire the boards up. I will be using one pot and the bridge and uno board you see in the pictures. I am wondering if some one could tell me where to hook the wiring up to each other? I am using a wiper motor to run it,and it wil only lean left and right. thanks for any help guys.
nave
Re: Need help please
Postby vicpopo » Sun 23. Mar 2014, 09:43
I ask myself a question : Did you search a little bit on this forum to find an answer ? :shock:
http://www.x-sim.de/forum/viewtopic.php?f=39&t=723#p5451
Postby sirnoname » Sun 23. Mar 2014, 13:37
Be carefully, this post do require some elctronical knowlege!
Heatsink for bridges, optocupler, diameters/max. lenth of wires and so on.
Starter use normally pololu interfaces.
Postby nave » Sun 23. Mar 2014, 20:10
vicpopo wrote:I ask myself a question : Did you search a little bit on this forum to find an answer ? :shock:
Yes that is how i found out what to use. I have one problem i did not get the Arduino board i got the one in the picture,I did not know i had the wrong one till it was to late. I know how to wire up the 5 volt and the ground,but i only have the uno bridge and the usb board and a pot + the 12 volt supply,is that all i need and will it work?
nave
