HELP Arduino Uno wiring - H-Bridge & Software
Postby xidsim1 » Mon 23. Dec 2013, 12:53
Hi Everyone,
Obviously I am new to this and also admittedly not very PC literate!
I have been interested in building a sim for a long time now and have finally got around to starting this which I will be doing over the christmas period as I will have time however, I have come to an early stop.
On my dual H-bridge i have several wiring options but I can not get the software to move my motors. It could be the software but firstly I would like to know whether I have wired it correctly although starting the software up seems to be a challenge as I get a problem as others when trying to test the '3D SimforceGT' when infinite error codes come up on my screen.
So, my confusion with all the wiring from the pc to the wiper motors is as follows:
On the wiring information for the H-Bridge it says "PWM, Enable & Current sense", these I do not understand.
Where do I connect the H-Bridge to the Arduino Uno.
Colour picture of H-Bridge
H-Bridge Input Output Connections & Jumpers
H-Bridge Wiring Options, I am trying to do the middle option with 2 x motors connected
The jumpers are connected:
J1 EAB = On, J1 CAB = On
H-Bridge = Arduino pin # connection
PA = 10
PB = 9
EA = 2
CA = 3
EAB = 4
CAB = 5
I have got the Blink LED on the Arduino and 2 x LEDs on the H-Bridge, Both motors connected I believe.
The X-PID has picked up the COMPORT 3 and in the X-PID window I have done the minimum and maximum values from the POTs
When I try the motor output & enter 10% or 90% on the x-sim window and press 'SET OUTPUT' nothing happens.
Have a done anything wrong with the wiring?
How do I get the motors to move with the 'X-Sim CONVERTER' software?
Can anyone help me please?
xidsim1
Re: Arduino Uno wiring - H-Bridge & Software 1st check
Postby sirnoname » Mon 23. Dec 2013, 14:34
Check first the pwm frequency and input voltage of the control circuit of your H-Bridge (both = 5V?).
Which arduino firmware are you using?
Re: HELP Arduino Uno wiring - H-Bridge & Software
Postby xidsim1 » Mon 23. Dec 2013, 15:11
PWM Frequency = DC - 20kHz
Input voltage Levels PA,PB,EA,EB : 2.5V - 5.5V = logic high, 1.7V = logic low
I downloaded firmware recently, i am just trying to check it....
xidsim1
Postby xidsim1 » Mon 23. Dec 2013, 15:29
i'm not sure I have found the correct firmware details but it says XPID.ino
if this is not what you asked then how do i find the firmware details?
xidsim1
Postby xidsim1 » Mon 23. Dec 2013, 16:02
im sure the firmware is Arduino 1.0.5 and plugin_1-4
xidsim1
Postby xidsim1 » Mon 23. Dec 2013, 17:01
does anyone now how to try and move the motors manually with the pc mouse or something like that?
xidsim1
Postby sirnoname » Mon 23. Dec 2013, 18:10
If you use xpid you have to wire like in the ino file described.
If your H-Bridge can use 20kHz this is good.
You can use the input setup percent entries to move manually
http://www.x-sim.de/manual/interface1.html
or you can use the test tablet of X-Sim instead of a game
http://www.x-sim.de/manual/test_plugin.html
Or you can pass through a joystick
or, or, or ...
Postby xidsim1 » Mon 23. Dec 2013, 18:38
for some reason i have no 'input' values on the 'All inputs of found interfaces' in interface settings... in the 'output' i have x 2 :
X-PID 1.4 COM3 position 1
X-PID 1.4 COM3 position 2
is this correct?
xidsim1
Postby sirnoname » Mon 23. Dec 2013, 18:54
Why you want input values?
Simple select the position 1 (Position control of first arduino output) and enter 10%, 50% and 90% as example.
Then set this new output. Motor moves to new position.
Postby xidsim1 » Mon 23. Dec 2013, 19:07
when you say to 'wire as the ino file describes' is that in the arduino XPID interface software coding? which i have
if so then i am not sure where to connect those arduino pins to the H-Bridge 'enable (EA)', 'current sense (CA)' & 'PWM (PA)', although i have swapped them and no difference anyway
INPUT VALUES:
In the interface settings, in the 'TEST one interface output pin' i put 90% hit the 'set output' button = no movement, just 1 flash from a LED on the Arduino PCB
in the 'TEST one interface input pin" there is next to the 'Result:''no input selected
Which the example HTML you sent has 'LPTI Digital InPin10 *......' and in "All inputs of found interfaces" and 'Result: 0%'
So i am wondering whether I am missing the PC not finding the 'LPTI' ?
xidsim1
