Dimension Engineering Position Control Module
Re: Dimension Engineering Position Control Module
Postby sirnoname » Wed 4. Dec 2013, 01:12
I think loading this values into the kangaroo is not wrong ;)
Postby Niko » Wed 8. Jan 2014, 15:18
"Hi Sir
I have a prolific usb to serial adapter, I had trouble getting Describe sw tool to work with it ok,
I used the adapter supplied with the roo to set the roo up, then swapped to the prolific to test with x-sim and that was ok.
using win xp
I can run some tests later in the week and post the describe config file if thats any help.
regards Terry"
do you try to control something with the Kangaroo with X-sim?
Niko
Postby telfel » Wed 8. Jan 2014, 21:39
Hi
I have only been testing with one motor, I have used Race 07 demo, and FSX with just one output effect, using the X-sim plugin, works fine
I have to rework my limit switch setup to mount them direct to the motor, I will then run more tests.
regards Terry
telfel
Images: 54
Been thanked: 9 times
Postby Niko » Wed 8. Jan 2014, 22:09
Can you show me how do you write it?
Niko
Postby Niko » Thu 9. Jan 2014, 09:15
I make a try yesterday, and now i can see my Kangaroo output into "Interface Setting"!!
i don't know why it's work * but it's work.
Niko
Postby Niko » Fri 10. Jan 2014, 14:38
Do i have to program X-sim with a Kangaroo like a K8055?
If yes, i had some good result with PID with K8055 (P=2, I=7, D=3) but not with the Kangaroo. My rig is too "nervous" * lol
Niko
Postby telfel » Fri 10. Jan 2014, 15:26
PID is set automatically using the auto tune function
Using the describe sw tool you can increase the dead band setting, then up load to the kangaroo
You can also change the pid in the software tool, but have not had to do that
telfel
Images: 54
Postby Niko » Fri 10. Jan 2014, 16:05
So you think i need to program X-sim on "analogue integer" instead of "dynamic speed value"?
Niko
Postby Niko » Sat 11. Jan 2014, 11:00
telfel wrote:
Niko wrote:Hi,
i check and by default in USO the comport is selected. I change for network. i change the number of port (now 11) and verify
if nothing is used in OBD2 setting. Nothing is assign.
always nothing in Output device.
You should not be using USO, the Kangaroo plugin uses the Synaptrix IO Output, I think you will need to clear the USO outputs.
Can you show me how your program this page?
I make different try yesterday and sometimes my computer crash! (never before) It's frozen and after a blue screen with some warning message and after reboot.
Very strange.
Niko
Postby telfel » Sat 11. Jan 2014, 11:31
Niko
Can you post screen sots of your system working using the describe sw tool, ie the output traces, this is where you also set the dead band if your system does not settle at the set position.
regards Terry
telfel
Images: 54
