Dimension Engineering Position Control Module
Re: Dimension Engineering Position Control Module
Postby Niko » Sun 17. Nov 2013, 18:00
It's working with sim tools. Or i need some different wiring?
Niko
Postby telfel » Mon 18. Nov 2013, 18:03
Check in device manager if USB interface is ok
The roo should show in interface settings as 2 channels with the com port number
telfel
Images: 54
Been thanked: 9 times
Postby Niko » Tue 19. Nov 2013, 20:16
Yes it's written "Prolific USB-to-Serial Comm Port (COM6)
I can see this Com Port in "Universal serial Output" of "Output Setup" tab.
Niko
Postby sirnoname » Tue 19. Nov 2013, 20:27
Double check that this comport us not used in USO or extractor OBD2 settings and try to increase the port number to 10 or above.
Postby Niko » Sat 23. Nov 2013, 13:03
i check and by default in USO the comport is selected. I change for network. i change the number of port (now 11) and verify
if nothing is used in OBD2 setting. Nothing is assign.
always nothing in Output device.
Niko
Postby telfel » Sat 23. Nov 2013, 23:24
Niko wrote:Hi,
You should not be using USO, the Kangaroo plugin uses the Synaptrix IO Output, I think you will need to clear the USO outputs.
telfel
Images: 54
Postby sirnoname » Fri 29. Nov 2013, 10:06
If the problem does exist:
Can you borrow me your setup for some days where you do not need them?
I think one day is enugh for profilic to kangaroo integration.
Postby Niko » Tue 3. Dec 2013, 19:29
Yes, but what do you need exactly?
Niko
Postby sirnoname » Tue 3. Dec 2013, 20:01
thats fine.
I need one of the profilic adapter and the kangaroo without any change of your current setup. Perhaps wired or some pictures of the wiring.
Thats all.
Send it to the address in the impress on the main page.
http://www.x-sim.de/software.php?lang=e ... =impressum
Back porto is not problem. Should fit into a cushioned cuvert I think, this is not expensive.
regards,
SirNoName
by the way, did you use the kangaroo tools to load the setup default? Maybe there you have a missconfig? Perhaps telfel can provide the default config here?
Postby telfel » Tue 3. Dec 2013, 22:15
Hi Sir
I have a prolific usb to serial adapter, I had trouble getting Describe sw tool to work with it ok,
I used the adapter supplied with the roo to set the roo up, then swapped to the prolific to test with x-sim and that was ok.
using win xp
I can run some tests later in the week and post the describe config file if thats any help.
regards Terry
telfel
Images: 54
