Dimension Engineering Position Control Module
Re: Dimension Engineering Position Control Module
Postby motiondave » Mon 29. Apr 2013, 14:48
looks perfect for someone like me,
simple controller for simple person.
:D
Postby motiondave » Tue 30. Apr 2013, 03:01
Ill tell ya what Bob.
I will donate $30 through paypal towards you purchasing a board and testing it.
Considering the last $25 I donated towards a control board for the community got no real results.
Postby telfel » Sun 21. Jul 2013, 20:18
Quick video showing Kagaroox2 auto tune
sorry about the quality
next video showing Kangaroo/Sabertooth operating from the Describe software to follow
regards Terry
telfel
Images: 54
Been thanked: 9 times
Postby telfel » Wed 24. Jul 2013, 22:05
Hi
Video of Kangaroox2 Sabertooth 2x60 test using manual slider of Describe software for position control.
regards Terry
telfel
Images: 54
Postby vicpopo » Tue 3. Sep 2013, 06:50
Hi Telfel,
I noticed that in converter there is a plugin for the kangaroo.What I not yet well understood is the wiring between the pc and the kangaroo and what is the function of the plugin.
I watched your video and your tests with the dimension engieeiring software but don't understand what is its utility because I suppose that the soft is unnecessary when xsim used.
Could you share some informations about this?
Postby telfel » Tue 3. Sep 2013, 08:14
vicpopo wrote:Hi Telfel,
Hi vicpopo
I am about to test the Kangaroo / Sabertooth with Sirs new plugin, I will then start a new post with all the details, I will need a little time as I have just returned from holiday and Ive had a small operation on my hand, so trying to do stuff with one hand at the moment.
In the video I was using the Dim Eng software to test the unit with my motors 375w 24v. To connect to the pc I'm using a usb to ttl converter,
24v input for the motors, 2 limit switches, hall effect 180' pot for feedback.
The sw tool allows for Autotune from the pc and to download / upload setting to the K/S.
Once the K/S is setup then the sw tool is not required, for the plugin to work.
As I said bare with me and I will post more details next week of the K/S working with Sirs plugin.
regards Terry
telfel
Images: 54
Postby sirnoname » Tue 3. Sep 2013, 11:13
The software of the vendor is used for setup. It is like the JRK utility. Closed source. If it get updates I do not have to support own updates.
X-Sim does autodetect the kangaroo and send position values but do not setup.
It is not possible to run the vendor software at the same time as X-Sim is using the hardware, which is different to JRKs.
The vendor software has some problems with some serial converters, X-Sim does work with all of them.
Postby vicpopo » Tue 3. Sep 2013, 13:40
Hi guy's,
Many thanks for your informations and supports !!
My old first 2dof simulator with saberbooth + velleman could be refurbished with this new kangoroo cheap board.
Since I gave back to my friend his finished 2 dof with sew gerared AC Motors and as I not yet really started a new 6 dof with ac geared motors , Driving on a simulator miss me a litlle bit. ;)
I will wait with eagerness your progres on this project.
Postby DannyT » Wed 16. Oct 2013, 11:08
I know, that there exsist a Kangaroo x2 plugin, but how to connect the Kangaroo to the PC (wiring)??
And for better understanding, the Kangaroo card does handle the position feedback itself. Together with the sabertooth
its a closed system like a r/c servo. So IMHO there should be two ways to control:
1) with a USB servo card (like mentioned already)
2) direct connection to the PC
Could someone please explain how to wire the Kangaroo to PC?
Hope to have some help here..
danny
DannyT
Postby telfel » Wed 16. Oct 2013, 14:39
DannyT wrote:I know, that there exsist a Kangaroo x2 plugin, but how to connect the Kangaroo to the PC (wiring)??
danny
For direct connection to PC running X-Sim converter
You need a usb to ttl converter the Tx line to S1, the Rx line to S2, 5v and gnd
The kangaroo can use a pot or encoder per channel for feedback, and 2 limit switches per channel for max and min position,
The Describe sw tool can then be used to auto tune the system, when your ok with the operation, you can then use the X-Sim converter plugin.
regards Terry
telfel
Images: 54
