Tronic H-bridge
Re: Tronic H-bridge
Postby Michael » Mon 9. Jul 2012, 17:48
i have change my small Car Wipermotors against big Golftrolleymotors (12V, 180W, 25:1 gear ratio, Rated Torque 5,5 Nm and Peak Torque 64 Nm :brows: ). I have do a Test and was wondering that the mosfet IRF3205 and IRF4905 was going very hot. With the Car Wipermotors there was no problem over the last years. What is the maximum temperature of these mosfets?. Perhaps i have to improve my mosfetcooling.
Can this H-bridge handle such big motors?. I don`t make a measurement till now, but i guess each motor take 20A at full Load.
In the old Forum someone wrote that i have to use the IRLZ44N instead of the IRF3205. Because of the temperature problem that is transmitted by the sink to IRF4905
Michael
Re: Tronic H-bridge
Postby Michael » Mon 9. Jul 2012, 18:09
Before testing with the bigger Motors, i did change the IRFZ44 with the new IRF3205
Michael
Re: Tronic H-bridge
Postby speedy » Wed 18. Jul 2012, 13:35
hi every one ...
I've made a 8 MOSFET ,full N-channel ,with a computer fan cooler for best cooling ,using the IR2110 MOSFET driver IC ...
http://www.x-sim.de/forum/viewtopic.php?f=43&t=246
speedy ;)
speedy
Has thanked: 14 times
Re: Tronic H-bridge
Postby tronicgr » Wed 18. Jul 2012, 15:35
That looks good! A little big but its one layer!! Double layer would make it a lot smaller.
Did you build that board yet? I think you should start a new project page with it and put more information like some more real photos of the assembled board and some video of it in operation!! Also some heating tests under load would be nice to know the temperatures that it can reach.
Re: Tronic H-bridge
Postby TheXRacer » Wed 15. May 2013, 22:54
Hello all,
I got my H-bridge (Tronic `s DIY dual MOSFET H-bridge) built.
Now I have always the problem that my mosfets overheat :oops: :o
Why is that everything is soldered properly! 3x checked! :)
P-channel MOSFET IRF 4905
N-channel MOSFET 44 IRFZ
All are constructed as in the plan, it all works just the mosfets too hot
Please write me back if you have a solution / assistance :P
best regards
Christian
TheXRacer
Images: 9
Has thanked: 5 times
Re: Tronic H-bridge
Postby wptm » Thu 16. May 2013, 09:06
TheXRacer wrote:P-channel MOSFET IRF 4905
I suggest to use IRLZ44N or IRL540N for N-channel. They require less volt to operate.
I've used IRL540N already, and now I'm waiting for the IRLZ44N. I need to replace the mosfets as I had a problem with my arduino controller, that it's opened both direction at the same time.
wptm
Images: 57
Re: Tronic H-bridge
Postby TheXRacer » Tue 21. May 2013, 20:39
Hi all,
have far v1.2b brought my H-bridge to work.
When I connect my car battery with the H-bridge, everything works fine (LEDs show the correct positions, and the connection to the AMC 1.6 works without problems!).
But as soon as I connect one of my wiper motors with the H-bridge go all LED's out!
The motor does not move one hears only a short jump of the motor does not move!
Can anyone help me?
I would be very grateful!
Greetings
Christian
Hallo ,
habe soweit meine H-Brücke v1.2b zum laufen gebracht.
Wenn ich meine Autobaterie mit der H-Brücke verbinde , funktioniert alles einwandfrei ( LED`s zeigen die richtigen Schaltstellungen an und die verbindung zum AMC 1.6 funktioniert ohne Probleme !!! ).
Sobald ich aber einer meiner Wischermotoren mit der H-Brücke verbinde gehen alle LED´s aus!
Der Motor bewegt sich nicht man hört nur ein kurzes springen des Motors keine Bewegung !
Kann mir irgendjemand helfen ?
Ich währe sehr dankbar dafür !!!
Grüße
Christian
TheXRacer
Images: 9
Re: Tronic H-bridge
Postby TheXRacer » Tue 21. May 2013, 21:40
nobody have a answer for me?
Please help me further I do not come on, try now been 8 months since my electronics to bring 100 percent to run, unfortunately without success
best regards
Christian
TheXRacer
Images: 9
Re: Tronic H-bridge
Postby Pablo » Tue 21. May 2013, 22:08
Hi, I have been using the Dsmhb of Tronicgr for a long time with no problem ...
You have isolated the ground of the wipermotor ? maybe there's your problem ..
Regards
Pablo
Images: 2
Re: Tronic H-bridge
Postby TheXRacer » Tue 21. May 2013, 22:24
Thanks for your answer !
Yes i have the Ground isolated from my wiper motor !
When i connected my H-Bridge to my ATX power -supply (PC) it works , and the problem is the motor loses much power !
I can stoped with my hand ....!!!
What is this ?
Thanks for any help !!!
regards
Chris
TheXRacer
Images: 9
