HELP Arduino Uno wiring - H-Bridge & Software
Re: HELP Arduino Uno wiring - H-Bridge & Software
Postby sirnoname » Mon 23. Dec 2013, 20:34
Why you need LPT1 if you have an arduino connected?
You have posted three option how to wire the bridge. None of this pictures are compatible with the arduino pinout in the ino file (far away). Which means this H-Bridge is not compatible with the standard ino file and you have to program a new one which supports two PWM for one motor as described in your manual.
Postby xidsim1 » Sat 28. Dec 2013, 17:17
do i need a game installed 1st before it will work when i connect everything?
xidsim1
Postby sirnoname » Sat 28. Dec 2013, 17:20
no, simple use the interface setup
Postby xidsim1 » Sat 28. Dec 2013, 17:22
sorry i didnt see the last message you sent on the 23rd
xidsim1
Postby xidsim1 » Sat 28. Dec 2013, 17:23
okie doke, where in the manual will i find how to set up the PWM for the motors?
xidsim1
Postby sirnoname » Sat 28. Dec 2013, 17:28
In your case you must reprogram the standard INO file OR use a H-Bridge with the coorect connections that are described in the Open Source XPID post.
You see this in the manual like you send us on page 1.
Postby xidsim1 » Sat 28. Dec 2013, 18:30
xidsim1
Postby sirnoname » Sat 28. Dec 2013, 18:38
Postby xidsim1 » Sun 29. Dec 2013, 19:26
Is this the page?
https://github.com/X-Sim/X-PID-Arduino- ... e/XPID.ino
If so it is quite confusing to me as I have no clue how to change the coding to run 2 x motors and what the 'PWM' 'enable' and 'current sense' means on my h-bridge.
I am willing to learn but need help as if you are teaching a child :?
So what is next for me to learn/do please?
xidsim1
Postby xidsim1 » Tue 7. Jan 2014, 14:07
Can anyone advise me how to write a new code for my H-Bridge?
As in simply send me a 'direct link' to the page that explains this.
Alternatively, send me a link to the best deal h-bridge that is compatible to wiper motors please.
xidsim1
