wiper motor problem
wiper motor problem
Postby runningwild82 » Thu 6. Mar 2014, 13:38
Hi, i've got 2 wiper motors in my 2DOF sim controlled with 2 pololu jrks, the one used for the pitch runs ok in both direction, but the one used for the roll is powerful enough only in the normal direction, when reverting is very weak... i've checked the settings of the jrk and it's ok... what could be the issue? thank you for your help!
runningwild82
Re: wiper motor problem
Postby thaparser » Thu 6. Mar 2014, 17:24
you may need to re-wire it, this involves opening it up do some soldering eventually and putting it back together.
if you're lucky enough, you may be able to solve the problem as shown here
good luck!
thaparser
Images: 26
Has thanked: 5 times
Postby runningwild82 » Thu 6. Mar 2014, 17:41
thank you for your reply, i'll try that and i'll report there
runningwild82
Postby runningwild82 » Thu 6. Mar 2014, 18:19
another thing, changing the speed does the torque change too? asking because my problem is not speed but is the power of the motor that in one direction manages without problems the load but in the opposite direction is just too weak... when i go home i'll test it without the load to see if there's a speed difference between directions
runningwild82
Postby thaparser » Fri 7. Mar 2014, 09:05
it really depends on the motor but more speed doesn't necessarily mean more torque.
however, maybe it has enough torque but because it doesn't have the speed it just feels lazy. you'll know better when you'll have the speed issue fixed.
thaparser
Images: 26
Postby telfel » Fri 7. Mar 2014, 16:37
Hi
Are you using this for flight sim or car racing?
Can you post a sketch of your motor positions / mounting points
regards Terry
telfel
Images: 54
Been thanked: 9 times
Postby runningwild82 » Sat 8. Mar 2014, 14:19
the trick of rotating the motor body worked for me! thank you so much!!!
@terry: is a flightsim based on the blu tornado project http://digilander.libero.it/tornadoblu5/en/index1.htm
runningwild82
Return to Motors
