look at this ...
Turn wrote:dearn - do you mean your scooter accelerated slowly, or you had a scooter motor on a bench unloaded and you found that it sped up slowly (because of inertia, etc.)? If it was the second scenerio, which motor did you have, and do you know its specs?dearn wrote:I had recenly a electric scooter, this engine is powerfull but starts very slow. Like a router (starts slow then after 2 sec it's on full speed).
[quote="dearn"][quote="Turn"]dearn - do you mean your [u]scooter[/u] accelerated slowly, or you had a scooter motor on a bench unloaded and you found that it sped up slowly (because of inertia, etc.)? If it was the second scenerio, which motor did you have, and do you know its specs?
[quote="dearn"]I had recenly a electric scooter, this engine is powerfull but starts very slow. Like a router (starts slow then after 2 sec it's on full speed).[/quote][/quote]
[/quote]dearn wrote:Turn wrote:dearn - do you mean your scooter accelerated slowly, or you had a scooter motor on a bench unloaded and you found that it sped up slowly (because of inertia, etc.)? If it was the second scenerio, which motor did you have, and do you know its specs?dearn wrote:I had recenly a electric scooter, this engine is powerfull but starts very slow. Like a router (starts slow then after 2 sec it's on full speed).
Unloaded it was speed up slowly. It was a e-scooter type like this:
