Feed back pots
Re: Feed back pots
Postby Riton » Mon 17. Sep 2012, 08:37
there are at Conrad, 360 ° potentiometers without mechanical stops.
For me it''s a good solution.
Riton
Images: 70
Been thanked: 16 times
Re: Feed back pots
Postby CraCk » Mon 17. Sep 2012, 20:16
Bruceaust wrote:Thanks crack,
I have seen those, they look great but they are very esxpensive.
16$ is expensive? :shock:
http://ru.mouser.com/BI-Technologies/Pa ... 27&FS=True
CraCk
Re: Feed back pots
Postby Bruceaust » Tue 18. Sep 2012, 00:49
I priced them through another supplier at about $80!!
Thanks I will check out Mouser :D
Bruceaust
Re: Feed back pots
Postby Bruceaust » Tue 18. Sep 2012, 05:19
$15 each plus $39 postage.
:shock:
Bruceaust
Re: Feed back pots
Postby motiondave » Tue 18. Sep 2012, 14:52
postage a killer for some reason....
I used 5 turn multiturn pots from RS Components on the foot motor sim. They cost me $35 each, but I had to put gears on them.
Re: Feed back pots
Postby Bruceaust » Wed 19. Sep 2012, 01:20
Yeah, if only we could find a supplier in Aus that does not charge the earth for these otherwise reasonably priced components.
I will keep everyone informed with my hall effect experiment. So far I have found some gears from Jaycar, Hall sensors and Magnets from eBay.
Total cost for each one should be less than A$10. Plus if it works it could be modified to suit different gear ratios of the feedback. I still like the idea of mounting the feedback on the output of the motor rather than measuring the frame motion.
Bruceaust
Re: Feed back pots
Postby CraCk » Thu 20. Sep 2012, 16:59
In www.digikey.com said: 6127V1A180L.5 the shaft rotates continuously (360 degrees) but during that rotation, the sensor is only sensing during 180 degrees of that rotation.
http://www.digikey.com/product-detail/e ... ND/2620657
I think that is the ideal solution for our projects. You can not be afraid that the engine provernetsya at 360° and damage sensor. It is worthwhile to spend money. Hall sensor and the magnet is a continuous problem. So I went to HRS100SSAB090.
CraCk
Return to Motors
