Fanatec ClubSport Pedals V1 modification
Postby matsuda » Tue 9. Oct 2012, 11:37
Hello, guys
I’m quite confident that most of you aware of the fact that you can easily adjust your ClubSport pedals.
But I’d like to give you few tips on what else could be done on them^
1. Inverted mounting
By default Fanatec pedals are supposed to be floor mounted. But I always wanted to be mounted upside down like so:
2. Custom pedal covers
I’ve found that if you invert-mount them stock pedal covers become really uncomfortable.
That’s why I’ve replaced them with custom pedal covers which are more ergonomic:
362
Bought them from ebay for around 50 USD
3. Damper for brake pedal
The pedal in its default position felt too soft to me. You can of course adjust it by changing the throw to one step.
But then it becomes really stiff and lacks the throw as well. So if decided to leave it in default position and added a damper to it
363
Result is:
- Adds up hydraulic feel to brake pedal
- Becomes more progressive
The price of the damper was around 15 USD
Check out my sim rig page
matsuda
Re: Fanatec ClubSport Pedals V1 modification
Postby Turn » Tue 9. Oct 2012, 12:36
Hey Matsuda. Thanks for sharing that. Can you elaborate on your brake pedal mod? CS pedals have a very stiff stock throw of only an inch or so because of the load cell. So, what did you do with that foam plug that sits on the load cell? Is it still in use? Normally, it compressing is the only thing that allows pedal travel. Is the travel still the same on yours?
Turn
Postby matsuda » Tue 9. Oct 2012, 13:12
Turn wrote:Hey Matsuda. Thanks for sharing that. Can you elaborate on your brake pedal mod? CS pedals have a very stiff stock throw of only an inch or so because of the load cell. So, what did you do with that foam plug that sits on the load cell? Is it still in use? Normally, it compressing is the only thing that allows pedal travel. Is the travel still the same on yours?
Hi, Turn
1. Please check what is your current throw position, is it the leftmost as it is on picture bellow? For me personally, the throw in such position is the best but it makes the pedal too soft. I did tried a stiffer setting but the travel of the pedal is not acceptable for me. That's why I've added up the damper to make the feel of the pedal more realistic in default position.
2. I would not recommend you to remove the foam from a load cell or replace it with something else. There is risk that you may brake the load cell as it might get crushed by metal rod of brake pedal. There are several instances of broken load cells on CSP previously.
matsuda
Postby Turn » Tue 9. Oct 2012, 18:21
Mine is 3 notches stiffer than yours. Travel about 1 inch. What is the total travel of your pedal?
Turn
Postby matsuda » Wed 10. Oct 2012, 09:39
Turn wrote:Mine is 3 notches stiffer than yours. Travel about 1 inch. What is the total travel of your pedal?
Wow, that is no wonder why you complained earlier about throw of pedal...
Travel of the brake pedal on mine is comparable to the travel of the clutch but with increased progression and stiffness. If think it is around 25-30 deg.
I can make a video later on how it looks like. Cheers.
matsuda
Postby Turn » Wed 10. Oct 2012, 09:48
I wasn't complaining, just stating. The pedal travel is okay with me. You don't need to bother about making a video, I understand your mod * Thanks.
Turn
Postby matsuda » Fri 12. Oct 2012, 09:28
Turn wrote:I wasn't complaining, just stating. The pedal travel is okay with me. You don't need to bother about making a video, I understand your mod * Thanks.
Sorry mate, I did not want to offend you. Peace :D
matsuda
Postby Turn » Fri 12. Oct 2012, 17:34
No offense was taken. Just trying to save you some time.
Cheers! :)
Turn
Return to Peripheral Projects
