New!!OBD2 Com with Xsim3 and Arduino-New!!
Re: New!!OBD2 Com with Xsim3 and Arduino-New!!
Postby sliversgyj » Wed 2. Oct 2013, 04:01
sirnoname wrote:RPM is /4. The formula is OBD2 standard.
The extended RPM with EA or EF is RPM/10 to reach 655350 RPM, you told something about above 100000 which is above 65535.
With laptime you are right, it is cutted to 65535 (FF FF) because I forgot to change it up. It must count up to this value then stay FF FF.
Did fix this for the future.
Thank for your info.but I still not understand why rpm need to reach 655350, is 65535 not big enough(i not sure which car will exceed such rpm)?and why you said that i told somthing above 100000?the value i test is 1236( the value is from the input data window).
sliversgyj
Images: 34
Postby sirnoname » Wed 2. Oct 2013, 23:20
Changed. RPM with EA is now 65535. Laptime should be working now with 3.0.2.8.
Postby sliversgyj » Thu 3. Oct 2013, 04:56
sirnoname wrote:Changed. RPM with EA is now 65535. Laptime should be working now with 3.0.2.8.
thanks a lot!now all the data are received.
sliversgyj
Images: 34
Postby Tombo » Sun 6. Oct 2013, 16:25
I got a question. I've nearly got all Parts together, but im not shure about the diodes fort the 7segment display. Or will it be safe to use without?
4n002 will be ok?
Tombo
Images: 36
Postby vicpopo » Sun 6. Oct 2013, 16:46
hi Tombo ,
Sorry for forgotten , very necessary I don't know !!!
Taken 1n819
Postby TheXRacer » Fri 11. Oct 2013, 17:55
Hey all,
I have the arduino uno connected to an LCD 162c, exactly as described on page 1st
If the code on the Arduino Uno was transferred data are not available (nothing)!
What is wrong, I still have to do what? :shock:
OBD2 is connected to the interface of the Arduino!
regards
Chris
TheXRacer
Images: 9
Has thanked: 5 times
Postby vicpopo » Fri 11. Oct 2013, 19:22
In xsim extractor did you go to the menu obd2 interface settings to add the com port ( which arduino plugged to and normally recognized by extractor) to the selected window comport to validate data transfer?
Postby TheXRacer » Fri 11. Oct 2013, 21:24
yes adruino the board is wired according to your plan and was in the extractor com.port connected! LEDs flash as in your video and the board is controlled only the LCD display indicates no data!
Could you please again check the wiring on page 1?
Should I post images?
Use only the lcd162c!
Thanks for your help!
TheXRacer
Images: 9
Postby vicpopo » Fri 11. Oct 2013, 22:17
Hi ,
New upload but the same program.just removed the zip file into the archive.
What do you watch on lcd display? Please make a picture
Postby TheXRacer » Fri 11. Oct 2013, 23:12
Images I do tomorrow (LCD panel) then you can see if I have everything wired correctly ;)
Otherwise very cool project with the Arduino!!! :D :D :D !!!
best regards
Chris
TheXRacer
Images: 9
Return to Peripheral Projects
