//E4 Current fuel (not elm327 complaint)
//E5 Current joy button state 0-7 with bit mask (not elm327 complaint)
//E6 Current joy button state 8-15 with bit mask (not elm327 complaint)
//E7 Current joy button state 16-23 with bit mask (not elm327 complaint)
//E8 Current joy button state 24-31 with bit mask (not elm327 complaint)
// X-Sim Sample code for receiving OBD2 values from the extractor without using the converter
// OBD2 is industry standard, X-Sim will additionally expand the OBD2 PID with gear and other values
// Usage:
// Arduino has to be connected to a free USB port on the computer where the extractor is running
// Open the extractor and open the settings menu, there you have to select the OBD2 menu
// Add now your arduino comport to the OBD2 list.
// After closing the dialog you will see the arduino LED will be enabled which represents receiving data.
// After closing the extractor application the LED will switch off.
// Pressing joystick button 2 (count from 0) will disable the LED for a short time
// Use this code to insert your own display code at the fitting positions
// Copyright 2013 Martin Wiedenbauer, X-Sim.de
// References:
// http://en.wikipedia.org/wiki/OBD-II_PIDs
// http://elmelectronics.com/DSheets/ELM327DS.pdf
// http://www.x-sim.de
bool extractordetected=false; //Will get updated from last positive or negative receive
int receivebuffer[20]={0}; //Receive buffer
void setup()
pinMode(13, OUTPUT); //Arduino UNO LED off
digitalWrite(13, LOW);
Serial.begin(9600);
//Do here stuff to init display and zero to default
int HexToInt(int c)
if (c >= '0' && c <= '9')
return c - '0';
else if (c >= 'a' && c <= 'f')
return c - 'a' + 10;
else if (c >= 'A' && c <= 'F')
return c - 'A' + 10;
else
return -1; // getting here is bad: it means the character was invalid
int ParseReceiveBuffer(int commandhighbyte, int commandlowbyte, int receivelength)
//First character is removed of the receivebuffer string and must not be verified again
if( receivebuffer[0]=='1' && receivebuffer[2]==commandhighbyte && receivebuffer[3]==commandlowbyte )
//Parse 2 byte values on position 5 and 6 in the buffer string
if(receivelength==7)
int highresult=HexToInt(receivebuffer[5]);
int lowresult =HexToInt(receivebuffer[6]);
if(highresult==-1 || lowresult==-1){return -1;}
return ((16*highresult) + lowresult);
//Parse 4 byte values on position 5,6,8 and 9 in the buffer string
if(receivelength==10)
int tophighresult=HexToInt(receivebuffer[5]);
int toplowresult =HexToInt(receivebuffer[6]);
int highresult=HexToInt(receivebuffer[8]);
int lowresult =HexToInt(receivebuffer[9]);
if(tophighresult==-1 || toplowresult==-1 || highresult==-1 || lowresult==-1){return -1;}
return ((4096*tophighresult) + (256*toplowresult) + (16*highresult) + lowresult);
return -1; //Something is wrong with the returned OBD2 echo command byte
//This function will wait for the first character in receivetrigger and will parse the result
int ReceiveValueWithTimeout(int receivetrigger, int commandhighbyte, int commandlowbyte, int receivelength)
int arduinoserialbuffer=0;
int buffercount=-1;
for(int z=0; z < 1500; z++) //1500ms timeout should be enough
while(Serial.available())
if(buffercount==-1)
arduinoserialbuffer = Serial.read();
if(arduinoserialbuffer != receivetrigger) //Wait until the trigger is reached, ignore echo, first character is not in the buffer
buffercount=-1;
else
buffercount=0;
else
receivebuffer[buffercount]=arduinoserialbuffer;
buffercount++;
if(buffercount > receivelength) //buffer has now waitlen character length
return ParseReceiveBuffer(commandhighbyte, commandlowbyte, receivelength);
buffercount=-1;
delay(1);
return -1;
void ClearReceiveBuffer()
Serial.read();
void SendEchoDisabled() //not used here and a part of the OBD2 ELM327 specifications, as INFO
//ATE0 Echo disabled
Serial.write('A');
Serial.write('T');
Serial.write('E');
Serial.write('0');
Serial.write('\r');
//010c Request RPM, remember: OBD2 RPM is ((A*256)+B)/4
int GetOBD2RpmValue()
//010c
ClearReceiveBuffer();
Serial.write('0');
Serial.write('1');
Serial.write('0');
Serial.write('c');
Serial.write('\r');
return ReceiveValueWithTimeout('4','0','C',10);
//010d Request speed in kmh
int GetOBD2SpeedValue()
//010d
Serial.write('0');
Serial.write('1');
Serial.write('0');
Serial.write('d');
Serial.write('\r');
return ReceiveValueWithTimeout('4','0','D',7);
//01e0 Request gear number
int GetOBD2GearValue()
//01e0
Serial.write('0');
Serial.write('1');
Serial.write('e');
Serial.write('0');
Serial.write('\r');
return ReceiveValueWithTimeout('4','E','0',7);
//01e5 Request current joystick button status 0 to 7
int GetOBD2JoyStatus0to7()
//01e5
Serial.write('0');
Serial.write('1');
Serial.write('e');
Serial.write('5');
Serial.write('\r');
return ReceiveValueWithTimeout('4','E','5',7);
//01e6 Request current joystick button status 8 to 15
int GetOBD2JoyStatus8to15()
//01e6
Serial.write('0');
Serial.write('1');
Serial.write('e');
Serial.write('6');
Serial.write('\r');
return ReceiveValueWithTimeout('4','E','6',7);
//01e7 Request current joystick button status 16 to 23
int GetOBD2JoyStatus16to23()
//01e7
Serial.write('0');
Serial.write('1');
Serial.write('e');
Serial.write('7');
Serial.write('\r');
return ReceiveValueWithTimeout('4','E','7',7);
//01e8 Request current joystick button status 24 to 31
int GetOBD2JoyStatus24to31()
//01e8
Serial.write('0');
Serial.write('1');
Serial.write('e');
Serial.write('8');
Serial.write('\r');
return ReceiveValueWithTimeout('4','E','8',7);
void loop()
int speed=0;
int rpm=0;
int gear=GetOBD2GearValue();
int joystatus=0;
while(gear >= 0)
if(extractordetected==false)
SendEchoDisabled(); //Will cause a OK\r as answer from the extractor, ignored in this code
extractordetected=true;
digitalWrite(13, HIGH); //We have connection and all values are ok, turn on the LED
//Read all values
gear = GetOBD2GearValue(); //Notice: offset +1 because of reverse gear
speed= GetOBD2SpeedValue();
rpm = GetOBD2RpmValue();
rpm=rpm/4 ; //remember OBD2 RPM is ((A*256)+B)/4
joystatus = GetOBD2JoyStatus0to7(); //Warning: X-Sim 3.0.2.6 needed as minimum
if(gear!=-1 && speed!=-1 && rpm!=-1 && joystatus!=-1)
//Show the button status if pressed (dark=pressed, light=not pressed)
if(joystatus==4) //Joystick bit 100 = Button 2 counting from 0
else
digitalWrite(13, LOW); //No connection, turn off the LED
delay(2000); //No serial connection, poll serial port all two seconds + readtimeout until a running extractor is detected
}sirnoname wrote:Make it sense to make it possible with a extra OBD2 command to get the latest joy button of the selected joystick (0 to 31).
You may then remove the buttons and can control the display with joystick?
For example:
request from arduino -> get 0 = no button pressed
request from arduino -> get 1 = button 0 is pressed
request from arduino -> get 2 = button 1 is pressed
request from arduino -> get 3 = button 0 and button 1 is pressed
With bitmask.
OR
request from arduino -> get 1 = button 0 was pressed
request from arduino -> get 2 = button 1 was pressed
Wich means that it was hold down, the release will not be sent. This means you get how often the button was set and the extractor will handle down and up events (no program part for arduino).
Or are all wheel buttons used?
That means maximum rpm value of 16383, which is not enough for example for F1 cars.
Remember: if you buy a OBD ELM 327 Interface with serial output you can connect your arduino gauge system to your car if it owns a OBD2 connector.
In this case you need to send the Echo Off command like in the current code and the ELM 327 car-autodetection command. Using OBD2 while driving is not allowed in some countries.
sirnoname wrote:There are different ways for input manipulations (Hooks, Keyboard events, DX commands) but also many against this because of cheating.
You need to send all three options because every game has another input reader connected to only one of this interfaces.
In case you need keyboard input with arduino you use native solutions instead:
http://arduino.cc/en/Reference/MouseKeyboard
This is more easier than software workarounds.
http://www.circuitsathome.com/mcu/hid-j ... ode-sample
In both cases the serial converter near the USB connector get reprogrammed as mouse, keyboard or joystick.
There are several projects in the net.
It is possible to make a descriptor with component devices (a type of internal HUB), this means arduino will get detected as mouse, keyboard and serial converter in one and the same device.
