Arduino UNO/Duemilanove 2dof firmware
Re: Arduino UNO/Duemilanove 2dof firmware
Postby prilad » Wed 1. May 2013, 19:15
Danis13 wrote:am.. ok this h-Bidge its ok?
http://www.ebay.es/itm/3v-36V-Dual-15A- ... 927wt_1163
BobBuilt wrote:Has the right pin out as Mr Prilad's diagram, plus 12v side of circuit look like they have been enlarged.
So without actually testing this driver myself but it seems to meet the specs needed.
Hi, guys.
I have the same H-Bridge (as you can see on video in the top of this thread). I tested this bridge with wiper motor and I think it works good.
Regards,
Ale
UPDATE: In this thread (on our Russian forum) you can see how to make ISOLATED radiators for this H-Bridge (if it necessary)
http://mal4x.ru/viewtopic.php?f=6&t=197&start=145
prilad
Been thanked: 37 times
Postby Danis13 » Thu 2. May 2013, 20:38
Hi I've read through the forum that the simplest way is to Pololu cards, but do not see any tutorial clear enough ... With the Arduino UNO if there is a tutorial that more or less with my little understand English, but I do not see a video where you see working, I think yours bob forum if you've done the work correctly with some servos.
What is the best way and I need?
Sorry for my bad English and for being something heavy thank you very much
Danis13
Postby spartan300 » Wed 3. Jul 2013, 11:18
hi,
i have this driver (DBK Dual Motor Driver) http://www.ebay.com/itm/221043792022?ru=http%3A%2F%2Fwww.ebay.com%2Fsch%2Fi.html%3F_sacat%3D0%26_nkw%3D221043792022%26_rdc%3D1#ht_12788wt_1344
can i connect it to arduino for use with big worm motors or do i need isolator?
thanks
spartan300
Images: 16
Postby prilad » Wed 3. Jul 2013, 12:27
spartan300 wrote:can i connect it to arduino for use with big worm motors or do i need isolator?
thanks
Hi, spartan300
Some words about isolators
Galvanic isolation of the power side (half-bridge and motors) from the control side (PC) is not mandatory, but is recommended.
There are two reasons for using galvanic isolation:
1 - Unfortunately due to the peculiarities of the computer power supply ( a desktop PC rather than a laptop) the PC ground has a potential of 110 V.
2 - Chip FT232 (USB-RS232 converter) is very sensitive to impact noises on the earth wire.
As an isolator can be used USB isolator (instead isolation between H-bridge and Arduino)
http://www.electronics-lab.com/blog/?p=17938
Regards,
ALE
prilad
Postby spartan300 » Wed 3. Jul 2013, 12:47
thanks
Hi, spartan300
Regards,
ALE
so , if i understand right, the problem is the pc power supply and not the power supply that connect to motor driver, which can interact with PWM signals.
My motor consum a lot of power, i have a power supply that gives 90A for both motors.
So can i connect direct my arduino direct to my motor driver?
thx
spartan300
Images: 16
Postby prilad » Wed 3. Jul 2013, 13:07
spartan300 wrote:
thanks
Hi, spartan300
Regards,
ALE
thx
You CAN connect Arduino to motor driver... But it is possible the big currents pulses will lead to erratic work of microcontroller...
prilad
Postby spartan300 » Wed 3. Jul 2013, 13:13
with this USB isolator i will prevent this possible erratic work of microcontroller?
Sorry but iam new in elecronics
Thx
spartan300
Images: 16
Postby prilad » Wed 3. Jul 2013, 13:21
spartan300 wrote:with this USB isolator i will prevent this possible erratic work of microcontroller?
Thx
I think so... But I can not guarantee 100%
Regards,
ALE
prilad
Postby Tombo » Sun 11. Aug 2013, 15:39
i'm using arduino Nano with sirs Firmware. When i put a vaalue in the send output box my motor will move and stop at this position and is making a grinding noise. The pot signal gets very rough at this point so it's sendind left and right values all the time. So should i use an isolator? Can i use the sparkfun in my project?
1972
Tombo
Images: 36
Postby Wanegain » Fri 3. Jan 2014, 00:51
prilad wrote:
menix wrote:oh
thx for this reply
do i have any other chance to run the sabertooth with arduino?
I'll try to make version for...
Hi prilad !
Any news concerning the Arduino and the sabertooth with your software ?
Thanks for the work ;)
Wanegain
