Arduino UNO/Duemilanove 2dof firmware
Re: Arduino UNO/Duemilanove 2dof firmware
Postby dualin » Tue 12. Feb 2013, 12:54
Hi, Thanks for your great job. I've installed an arduino with this firmware in my sim and connected with a tronic dual h-bridge, it has worked a few hours and then the bridge had broken again. Then I'm looking to buy a new ones, what do you think about this H-bridge?
http://www.ebay.es/itm/2pcs-Double-BTS7 ... 2818wt_922
Will works fine with arduino?
How must I connect with my arduino??
Thanks in advance and sorry for my poor english.
Best regards
Dualin
dualin
Images: 7
Postby prilad » Wed 13. Feb 2013, 12:07
Hi, Dualin.
dualin wrote:I'm looking to buy a new ones, what do you think about this H-bridge?
Unfortunately you cannot directly connect this driver to Arduino. This driver is "full-bridge" (based on two H-bridge drivers)
But you can use simple addition schematic with only one chip 74LS08 like this:
Arduino to full-bridge connection diagram
Regards,
Ale
prilad
Been thanked: 37 times
Postby dualin » Wed 13. Feb 2013, 13:02
prilad wrote:Hi, Dualin.
But you can use simple addition schematic with only one chip 74LS02 like this:
Regards,
Ale
Thanks a lot Ale. Can you explain me a little more the connections???. I can't understand your schematic. I know only a little about electronic.
Thanks in advance
Dualin
dualin
Images: 7
Postby cubizme » Wed 20. Feb 2013, 13:41
Hi Alex,
Thank you very much :D . I've tested successfully, maybe weekend I will finish my sim ...
Now, I will show a short video about my project,
Best Regards,
Lê Trung
cubizme
Images: 73
Has thanked: 9 times
Postby dualin » Tue 26. Feb 2013, 06:53
Hi, tomorrow will arrive the H-bridges, and I've the 74ls02. Can you explain me the connections, please???
Thanks in advance
Best regards
Dualin
Regards,
Ale
Thanks in advance
Dualin
dualin
Images: 7
Postby prilad » Sun 3. Mar 2013, 17:20
BobBuilt wrote:Hopefully thats all correct and to ask another question can we uses pins on the other side to run the second H bridge or do you recommend building a second card to run the other unit.
Hi, Robbie!
I think you can use one chip 74hc08 for controlling TWO Bridges from ONE controller (like Arduino).
But you have check the accuracy of Ground wires connect from power supplies.
Regards,
Ale.
prilad
Postby denizelmas » Mon 4. Mar 2013, 00:37
fine !
denizelmas
Images: 16
Postby Danis13 » Tue 30. Apr 2013, 20:10
Hi men good job.. if got a little question i can use arduino Mega 2560 ??
Danis13
Postby Danis13 » Tue 30. Apr 2013, 21:48
Thank you so much Bob. Then buy you a Arduino UNO ...
Also I have this bridge H it's ok?:
http://www.ebay.es/itm/Dual-H-Bridge-Mo ... 985wt_1163
Danis13
Postby Danis13 » Wed 1. May 2013, 16:58
Danis13
