Postby sirnoname » Mon 18. Feb 2013, 00:51
Read the first post.
Postby rohithkumar » Mon 18. Feb 2013, 09:35
Hi sirnoname,
Thank you for the reply, But the link on the post you have directed me is not working..I mean it is downloading in the php format. I don't know what to do with it.
Any help???
rohithkumar
Postby sirnoname » Mon 18. Feb 2013, 09:50
Both links (Github and zip) are working very good as you can see by the download count.
Postby rohithkumar » Mon 18. Feb 2013, 10:24
I dint know what happen yesterday but today i have tried,it is working :o any way thank you.
rohithkumar
Postby rohithkumar » Mon 18. Feb 2013, 11:37
Yes you are right..I dont know what happened yesterday I dint work for me, I have downloaded the Firmware and plugin as directed.Now X-sim is detecting the interface.
I am little confused that is this firmware is enough to drive the motors using x-sim output or i have to upload the program which is written for it. If i upload the program will the interface detect the board. I may be asking silly question but i am stuck here.
rohithkumar
Postby sirnoname » Mon 18. Feb 2013, 16:32
Upload the sketch to the arduino, copy the plugin to the interface plugin directory of x-sim. Look into the converter interface setup and it must be detected.
I am working on a update for nano and other older arduinos with ftdi chip, if you do not use the UNO R3 you have to wait until V2 of the code.
Postby rohithkumar » Mon 18. Feb 2013, 19:38
I have followed you instructions in all possible ways i know or gathered in the mean time. I am Using Arduino Uno R3 I can give you a narrow area where i am struck :?:
Arduino is easily detected by X-sim and I can see the RX,TX blinking when i open USB-XPID settings.
I think the values generated by x-sim from game in Math setup are not been taken in to output setup or the values from output setup are not given out to the board. I have been following your instruction from start for settings of the profile, math and output setup.
Now i dont have any option to try my self :( :?:
Can you give me any other direction where i can solve this issue
You are doing a great job in helping starters like me thank you...
rohithkumar
Postby sirnoname » Mon 18. Feb 2013, 19:53
hmm, did you read the pololu thread for the setup between math and interface?
viewtopic.php?t=673
Postby rohithkumar » Mon 18. Feb 2013, 22:11
:idea: I am planning to update my ATmega8U2 chip firmware on Arduino board. I have found that my boards ATmega8U2 chip firmware is not up to date, by following the instructions on the following link.
http://arduino.cc/en/Hacking/DFUProgramming8U2
Do you think this will help me in resolving serial communication issue?
Regards
rohithkumar
Postby sirnoname » Mon 18. Feb 2013, 22:19
which issue?
